Dual layer DVD playing in MOS
    GK_LKA
    Posts: 481 from 2004/3/28
    Ok, so please help me: I have an original dual-layer DVD, and can't play it on MOS 1.4.5. I can't even copy or play the VOB the files from the DVD (it says R/W error). Tryed MPlayer 1.0pre7 with the VOB files (MOS dropped R/W error), with dvd:// (can't found some files), with MPlayer 0.91 dvd:// (crashes).
    So please tell me how (and with) to play a simple DVD on my Peg...
    [ GK / LKA Team ]
  • »25.05.06 - 22:08
    Posts: 918 from 2004/1/24
    Had some problems with 1.0pre7 and DVD's as well. Try 1.0pre4 instead
    http://nogfx.free.fr/warpdesign/download.php?file=MPlayer10-PRE4.lha
  • »25.05.06 - 22:22
    CISC
    Posts: 619 from 2005/8/27
    Never ever play VOBs directly from DVDs...
    First off doing so will not work on encrypted DVDs (R/W error), and secondly it will play back wrong and several features will be inaccessible.
    Other than that, do you use the correct device/unit when using dvd:// access? ..and with 0.91 you have to use "-dvd-device <device>:<unit> -dvd <titlenumber>" instead of dvd://...
    - CISC
  • »26.05.06 - 03:30
    Jupp3
    Posts: 1193 from 2003/2/24
    On the other hand, it might be faster that way. But if you do so, expect problems.
  • »26.05.06 - 06:24
    GK_LKA
    Thanks for answers, now mplayer 1.0pre4 works almost fine (still has some framedrops on my G4, and doesn't support double buffering, so subtitles are flickering). 1.0pre7 (with the correct -ide-device option :) plays the disc with double buffer fine, but it skips back to the begin of the film after the half of it (maybe dual-layer problem?), and doesn't have OSD at all.
    Well, there is now MPlayer0.91 for internet streams, 1.0pre4 for DVDs and 1.0pre7 for simple video files. Cool :)
    [ GK / LKA Team ]
  • »26.05.06 - 07:27
    XzIt
    Posts: 250 from 2005/1/19
    The reason why you can`t copy the .VOB files, is Copy protection..
    The Answer to this is to use DVDShrink, the you will get a copy you can accualy COPY the .VOB files from.  :-D
    The Mplayer Support for DVD playing is`t great yet, i got the meassage that i had to LOW CPU and i own 1Ghz.  :-(
    But when i copyed the files to HD, it works great. 8-)
    XzIt of Apathy  8-)
  • »26.05.06 - 07:33
    Wishmaster
    Posts: 342 from 2003/6/29
    Try reading the manual of mplayer.
    It has lots of interesting options.
    Use the -chapter option to avoid getting files bigger than 2 GB, e.g. -chapter 1-5 and so on.
    Pegasos PPC
  • »26.05.06 - 09:14
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    GK_LKA,
    dunno about 1.0pre4, but 1.0pre7 can play network streams as well. About DVD playback i couldn't really tell as i don't have any DVD to test, but it uses the same code as 1.0pre4 anyway (plus a fix somewhere).
  • »26.05.06 - 09:54
    GK_LKA
    @XzIt:
    Erm, must have a pc to play DVD's on MOS? :)
    @Whismaster:
    Ok, I can live without the DVD menus, chapter selections, etc, but then let me play the whole DVD in one part without having to give which chapters you want to play... :/ (Only 1.0pre7 has problem with it.)
    Hm... I noticed reading DVD's on MOS is very-very slow. Is it possible that it is the problem, not mplayer?
    [ GK / LKA Team ]
  • »27.05.06 - 10:28
