Best text editor?
    TrevorDick
    Posts: 130 from 2005/10/12
    Unless I have missed something in my attempts to install MOS PUP there is not a text editor or edit utility supplied with MOS? What software would users recommend for editing text files like startup-sequences etc? Thanks.
  • »26.05.06 - 09:32
    guruman
    Posts: 462 from 2003/7/21
    You're not wrong: there's no text editor included with MOS 1.4.x yet (this is said to be subject to change with 1.5).
    I would suggest you to register at MDC: http://developer.morphosppc.com/ . Download and install the SDK, it has quite a lot of useful things (including a full Geek Gadgets installation) and you can download also a free version of GoldEd (namely: MorphEd) that is quite good.
    Or you could search on Aminet for eNote and Wordpad, both MUI based, both 68k, both working good on MorphOS...
    Kind regards,
    Andrea
  • »26.05.06 - 09:56
    hooligan
    Posts: 1948 from 2003/2/23
    http://www.aminet.net/search.php?path=text/edit
    take a pick ;-)
  • »26.05.06 - 09:57
    TrevorDick
    @hooligan
    take a pick
    Exactly!;-) I had already checked aminet, that's why I was asking for recommendations.
  • »26.05.06 - 10:03
    TrevorDick
    Andrea,
    Thanks for the advice. I had already checked aminet and needed some guidance to separate the "wheat from the chaff" ;-)
  • »26.05.06 - 10:11
    hooligan
    try them all.. each to its own. Something suitable for someone else doesnt necessarily cut for you.
    Cygnus Ed can still be bought, I would recommend it myself.
  • »26.05.06 - 10:57
    TrevorDick
    Thanks, I think I still have a copy which I bought for my A4000 several years back. I'll dig it out and also give it a try.
  • »26.05.06 - 12:09
    Posts: 1521 from 2003/2/24
    BlacksEditor is my favorite.
  • »26.05.06 - 12:11
