Configuring MOS-CONHandler
    munk
    Posts: 94 from 2006/3/27
    Is it possible to configure the MorphOS ConHandler? I would like to change the TAB-completion behaviour but I don't know if thats possible and/or if some documentation exist.
    Can KingCON be used with MorphOS or should it be better avoided?
  • »17.05.06 - 11:59
    gunne
    Posts: 441 from 2003/2/25
    munk,
    Have You tried MUICon ?
    Best wishes, Gunne
  • »17.05.06 - 14:09
    CISC
    Posts: 619 from 2005/8/27
    Sure, AFAICR it supports pretty much all the options that KingCON has, plus tons more...
    Unfortunately there is no documentation, but there are plenty of configuration options .. anyway, how do you want to change TAB-completion?
    You can change settings per window in the CON: line, or globally in ENV:CON.prefs (same line as for CON: (without CON:)) .. for TAB-completion there is the FNCMODE option, which takes W(indow), L(ist), C(ommon), B(rowse), S(ilent), Q(uote) and D(otInfo) as args...
    You can, but I don't see the point in doing so.
    - CISC
  • »17.05.06 - 18:57
