rtl_8139pci.device 50.12 100mbit fix patch
    Piru
    Posts: 624 from 2003/2/24
    This semi-official patch should fix the rtl_8139pci.device to handle 100mbit speeds properly.
    Download it from: rtl8139-50.12-100mfix.lha
    Install instructions are inside the archive.
  • »07.05.06 - 08:41
    Posts: 919 from 2004/1/24
    thanx :-)
  • »07.05.06 - 18:10
    Posts: 1932 from 2003/10/19
    It fails for me. Here is what i get.
    file rtl_8139pci.device-50.12.pch not found
    Patch Failed, file MOSSYS:Devs/Networks/rtl_8139pci.device not changed
    Hit Return
    I have the CD in the drive and i have spatch in C. Not sure what the problem can be.
  • »07.05.06 - 18:46
    SoundSquare
    Posts: 1214 from 2004/12/1
    it worked for me but i haven't tested the network speed yet.
  • »07.05.06 - 19:24
    I got it to work I think. I moved the file into the devs dir and then in my cli I changed to the dir and ran the command again. How do I tell if I am at 100Mbit now or not? I use MiamiDX.
  • »07.05.06 - 19:25
    Jupp3
    Posts: 1193 from 2003/2/24
    Probably the easiest way to tell is by the lights on the card (if it has 10/100Mbit light)
    But if you can't *feel* the speed difference, does it really matter, if it's 10 or 100Mbits? ;-)
    Obviously it affects mostly the speeds in local area network.
  • »08.05.06 - 10:51
    Piru
    Indeed the speed difference isn't visible in normal web browsing, IRC or so. You can only see it when you transfer large amounts of data in LAN (for example large smb or ftp transfers).
    Also, it should be pointed out that the 100mbit speed already worked with certain configurations (for example my old 100mbit switch gave 100mbit, while the new gigabit switch gave only 10mbit. In fact, this behaviour lead me to the bug).
    [ Edited by Piru on 2006/5/8 15:19 ]
  • »08.05.06 - 11:16
    Piru
    There was a small outage due to networking HW failure. The server is back up now.
  • »09.05.06 - 05:14
