Posts: 204 from 2003/12/29
I have a DVD with 25 files, 4.4GB, no sessions.
But from MorphOS I can only see 16 files, 2.8 GB! When I boot on the Linux side, the DVD is perfectly readable. I copied the files in an ext3 partition and later accessed normally from MorphOS with the ext2 driver.
Is there any limitation with DVDs in MorphOS?
Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
-- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
-- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
EFIKA
