MLDonkey and gnutella networks
    AmigaMancer
    Posts: 265 from 2005/8/25
    Hello.
    Before reading Jupp3's post about MLDonkey in the"torrent for MOS" thread, i had the same problems that he describes:
    Well, the newest version seemed to get "stuck" for me (No signs of life from f.ex. telnet interface) but can be quit with ctrl-c. The problem is you don't know when it will get stuck, and when it does, it obviously doesn't do anything. I downgraded to older version. Some people say that changing task priority to higher might help.
    Now, i have raised the task priority to 2 and for the first time ever, i managed to download an mp3 file!! :-)
    It still freezes relatively often, though (d*mn!) :-x but less often than before. When it does, the browser doesn't react in any of the MLD GUI's options. It just idles.
    The reason that i opened this thread is that i can't connect to the gnutella and gnutella2 networks, although i have set the enable_gnutella and enable_gnutella2 variables to TRUE.
    I haven't touch the setings in the gnutella.ini and gnutella2.ini files as i don't really understand them and thus i don't feel confident to change them.
    The "connected servers" option reports:
    --- Connected to 4 servers on the Donkey network ---
    [Donkey 17] 212.112.243.146:4661 www.UseNeXT.to
    Users:73915 Files:13661610 State:Connected
    [Donkey 18] 213.251.136.83:4661 ChezToff 2 (Serveur Fr)
    Users:49193 Files:7370294 State:Connected
    [Donkey 117] 83.149.72.193:13661 www.SofortDownloads.de #11
    Users:8534 Files:1428689 State:Connected
    [Donkey 149] 209.204.61.6:6666 SuckSmutGremlins
    Users:29268 Files:346744 State:Connected
    --- Connected to 0 servers on the G2 network ---
    --- Connected to 0 servers on the Gnutella network ---
    The "cient stats" option reports:
    Uptime: 0 days, 00h:05m (= 337 seconds)
    Successful Connections: 11
    eDonkey: 0 ( 0.0 %)
    old mldonkey: 0 ( 0.0 %)
    new mldonkey: 0 ( 0.0 %)
    Overnet: 5 ( 45.5 %)
    eMule: 6 ( 54.5 %)
    server: 0 ( 0.0 %)
    trusted mld: 0 ( 0.0 %)
    cDonkey: 0 ( 0.0 %)
    xMule: 0 ( 0.0 %)
    shareaza: 0 ( 0.0 %)
    aMule: 0 ( 0.0 %)
    lPhant: 0 ( 0.0 %)
    ePlus: 0 ( 0.0 %)
    Hydra: 0 ( 0.0 %)
    FastTrack doesn't work either as you probably know, but never mind about that as it is covered by AmiGift. (From what i read in the .guide, i haven't try it yet)
    I have a simple dial-up connection without any firewalls. If someone has a suggestion about what settings i should change in the downloads.ini and gnutella[2].ini files to make these networks operational, pleast post it.
    Advices on how to optimise MLD for a dialup connection and a 603 CPU (MLD seems to hog all of my CPU after a while) are also very welcome. Thank you.
    [ Edited by AmigaMancer on 2006/5/8 0:58 ]
    Amiga 1200 user.
  • »07.05.06 - 23:56
    AmigaMancer
    About the MLD hangs, btw: After doing some tests, i _think_ that i found what causing them. It`s the overnet network but i`m not exactly sure yet. I need to do some more tests on this.
    Also, this network is causing extreme network activity. My modem works constantly like crazy when i have it activated, even when everything is on idle and i`m not downloading anything. I wonder if this is related with the hangs..
    Amiga 1200 user.
  • »08.05.06 - 02:38
