MorphOS CyberGFX - GFX-card supported video modes info?
    BigGun
    Posts: 150 from 2004/6/18
    Is their somewhere an overview which video-modes the MorphOS CyberGFX Gfx-card drivers do support in which MorphOS version?
    For example I want to know which GFX-card driver supports 16bit color modes with big-endian GFX-mem layout and which GFX driver runs in little Endian slow mode.
    The reason for this is that little endian modes of course need a endian conversion which slows down the video a lot.
    SDL uses for endian conversion a 128KB lookup table.
    The runtime conversion doubles the required memory bandwidth so it basicly kills most games.
    Many thanks for the info
    Gunnar
    [ Edited by BigGun on 2006/4/22 17:44 ]
  • »22.04.06 - 16:43
    CISC
    Posts: 619 from 2005/8/27
    The quickest way to generate such an overview would be to get ppl with different kinds of gfxcards to run "sys:tools/showcgxconfig debug" and paste the "Available pixel formats" line .. f.ex. right here in this thread. ;)
    - CISC
  • »22.04.06 - 23:41
    Henes
    Posts: 507 from 2003/6/14
    I fear you ask the wrong question to solve the wrong problem :-)
    What you really want is to avoid on the fly pixel format conversion during blits.
    So, you should check SDL_DisplayFormat() docs.
  • »22.04.06 - 23:42
    BigGun
    CISC: Thanks for the tip:
    Okay SO let me begin to send some info then:
    cgxsystem.library 50.1 (PPC mode)
    1 graphics device(s) installed
    DEVICES:
    Voodoo3: Driver Version 4.9 (PPC mode)
    Prod=4634/5($121a/$5)
    BaseName=Voodoo3
    CardID=14($e) Number=1($1)
    Developed by 3Dfx Interactive, Inc.
    BoardBase=$ebff0000
    DrvrBase=$20875350
    Available pixel formats: LUT8 RGB16PC ARGB32
    Supports: Doublescan Gamma
    Maximum memory available: ~16.0 MBytes
    Memory clock: ~166.2 MHz
  • »22.04.06 - 23:51
    CISC
    Henes' suggestion is probably more sensible though... ;)
    - CISC
  • »22.04.06 - 23:57
    BigGun
    @Henes,
    Display format conversion during blits is *very slow* of course.
    But to be honest I'm abit worried about SDLs feature to emulate big endian GFX memory on little endian GFX-Cards.
    I think this feature is really slow, isn't it?
    If I look at the pixel swapping routines in cgximage.c
    The old Amiga version used the work with 128kb swapping tables even - LOL. But the new PowerSDL is still not optimal.
    The surface is read (one read per pixel),
    the pixel is swapped, and then written back (one write per pixel)
    This is very uneffective of course and could be done with one memory access per two pixels. And on PPC we could save all the swap command by using loads that do endianconvertion.
    I'll need to look a bit more into this to get a better understanding ...
    Henes, I have trouble compiling PowerSDL
    I'm getting this error.
    IMG_jpg.c :174 'JFIF_BASE_NAME' undeclared
    Do you know by chance how to fix this?
    Cheers
    Gunnar
  • »23.04.06 - 00:46
    BigGun
    Okay here the CyberGFX information of another card
    DEVICES:
    Radeon: Driver Version 4.1 (PPC mode)
    Prod=4098/20825($1002/$5159)
    BaseName=Radeon
    CardID=9($9) Number=1($1)
    Developed by ATI
    BoardBase=$e7ff0000
    DrvrBase=$2085cc8c
    Available pixel formats: LUT8 RGB15 RGB16 BGRA32
    Maximum memory available: ~32.0 MBytes
    Memory clock: ~182.7 MHz
  • »23.04.06 - 00:56
    Bladerunner
    Posts: 418 from 2004/2/19
    Here is mine, Radeon 9000:
    Installed libraries:
    DEVICES:
    Prod=4098/18790($1002/$4966)
    BaseName=Radeon
    Developed by ATI
    BoardBase=$ebfdb000
    DrvrBase=$20774b04
    Available pixel formats: LUT8 RGB15PC RGB16PC BGRA32
    Maximum memory available: ~64.0 MBytes
    Memory clock: ~200.7 MHz
  • »23.04.06 - 03:37
    roschmyr
    Posts: 207 from 2003/2/20
    Radeon 8500
    DEVICES:
    Prod=4098/20812($1002/$514c)
    BaseName=Radeon
    Developed by ATI
    BoardBase=$e7fea000
    DrvrBase=$20440154
    Memory clock: ~275.0 MHz
    Radeon 9200
    DEVICES:
    Prod=4098/22881($1002/$5961)
    BaseName=Radeon
    Developed by ATI
    BoardBase=$e7fef000
    DrvrBase=$2034c354
    Maximum memory available: ~128.0 MBytes
  • »23.04.06 - 07:15
    Robin
    Posts: 741 from 2003/2/24
    Radeon 9200 SE
  • »23.04.06 - 08:34
    Henes
    I do not understand what SDL emulation feature you are talking about.
    Just use SDL_DisplayFormat() at load time to convert all your bitmaps. Not in-game. Then you do not care if it is dead slow or not.
    RTFSDLM :-p
    About the error... look at the source, see the define around it and disable it in the makefile.
  • »23.04.06 - 16:38
    BigGun
    @Henes
    LOL, I know about SDL_DisplayFormat() :-)
    What I was talking about was SDL ability to emulate a big endian gfx-memory to the user (developer) even if the gfx-card is in reality in little endian.
  • »23.04.06 - 19:56
    BigGun
    INFO of another MOS-supported GFX_CARD
    DEVICES:
    SiS6326: Driver Version 4.4 (PPC mode)
    Prod=4153/25382($1039/$6326)
    BaseName=SiS6326
    Developed by Silicon Integrated Systems Corp.
    BoardBase=$ef7f0000
    DrvrBase=$20873d20
    Available pixel formats: LUT8 RGB15PC RGB16PC BGR24
    Supports: Doublescan Interlace Gamma
    Maximum memory available: ~4.0 MBytes
    Memory clock: ~66.0 MHz
  • »29.04.06 - 15:51
    BigGun
    And Another GFX card.
    This time an ELSA GLORIA SYNERGY SA
    AGD Card (with Permedia2 Chip)
    DEVICES:
    Permedia2: Driver Version 4.4 (PPC mode)
    Prod=4172/15623($104c/$3d07)
    BaseName=Permedia2
    CardID=12($c) Number=1($1)
    Developed by 3Dlabs
    BoardBase=$ef7d0000
    DrvrBase=$2085cbe0
    Available pixel formats: LUT8 RGB15 RGB16 ARGB32
    Maximum memory available: ~8.0 MBytes
    Memory clock: ~83.0 MHz
  • »29.04.06 - 16:00
