"Music makes your Summer" with Voyager?
    igracki
    Posts: 460 from 2003/2/24
    I couldn't visit the coca-cola website to select songs for my free music cd.
    The site says I need a flash plugin, but Voyager has a flash plugin, I tried to use the spoof settings but I had no success;-(
    Is the flash plugin too old?
    Is there maybe an update for the flash plugin?
  • »08.08.03 - 11:13
    warface
    Posts: 653 from 2003/2/24
    Voyager has V4 Flash plugin. You can have more recent under MacOnLinux only AFAIK. (LinuxPPC support of Flash is poooooooor)
    Most sites out there may require more up to date Flash, even if it's not really required. Just as there are thousands of Internet Explorer only sites.
  • »08.08.03 - 12:14
    porneL
    Posts: 49 from 2003/7/16
    Voyager - as all amibrowsers - is heavily outdated :(
    It completly lacks even basic css support, weak support for javascript. And flash plugin is too unstable to be used at all. For anything else than aminet is use Opera on pc :/
    this text is here to confuse you
  • »08.08.03 - 23:32
    DethKnight
    Posts: 139 from 2003/6/24
    just came from there, you're not missing much
    so don't sweat it.
    I am ; therefore you are
  • »09.08.03 - 03:20
