MOSNet + Apache
    GK_LKA
    Posts: 481 from 2004/3/28
    Ave!
    I've installed MOSNet, and am satisfied with it, but I have a little problem: my old Apache installation works only in Inetd mode - but MOSNet doesn't support this method. I've found a newer version (1.3.33) on Aminet, I think it can run in standalone mode, but it didn't work for me. When I start it first time, it says, that "bad user name www" (I have configured it, but maybe wrongly), second time it eats 100% CPU time for 10-15 seconds and then says that has problems with memory allocation (malloc()), then quits.
    So please, could anybody help me to install a working Apache? It is very important for me.
    [ GK / LKA Team ]
  • »15.03.06 - 17:21
    dIGIMAN
    Posts: 273 from 2005/11/7
    I use inetd from the amitcp 4.3 package which i run in the startnet script.
    All my inetd based programms with fine with mosnet and amitcp inetd.
    Ofcourse the config files have to exsist in the right folders
    eg. amitcp:db/inetd.conf etc
  • »15.03.06 - 17:29
    GK_LKA
    Ok, where can I get AmiTCP? Is it free or is there existing a demo? On AmiNET I've found only 4.0 demo and some really old versions.
    [ GK / LKA Team ]
  • »15.03.06 - 19:42
    Wishmaster
    Posts: 342 from 2003/6/29
    ehem
    Pegasos PPC
  • »16.03.06 - 11:11
    Posts: 408 from 2004/7/15
    The solution is: remove "user" from configuration at all. Apache won't re-login then.
    Or install usergroup.library and set up corresponding user/group in /etc/group and /etc/passwd.
    iPod, iBook, iMac,... iRobot?
  • »17.03.06 - 10:59
    GK_LKA
    Could you please tell me how? :) I don't know which files I have to edit or what to write in them.
    [ GK / LKA Team ]
  • »17.03.06 - 13:38
    Hmmm... How are you going to manage your Apache then? :)
    It's in httpd.conf. Just search for "www", you'll find the line.
  • »22.03.06 - 06:52
    GK_LKA
    Tested and does not work. The only thing has changed is that Apache doesn't write the error message anymore. I just simply quits. At second start it crashes the whole system.
    What I've done: I had a working installation of Apache witch MiamiDX and Louise's Apache 1.3.27 in inetd mode (this version supports only inetd). The I've downloaded this package, and replaced the old /apache/bin/httpd file with the new one. Then changed the /apache/conf/httpd.conf: I wrote #'s before the user and group lines, and changed the ServerType from inetd to standalone.
    [ GK / LKA Team ]
  • »22.03.06 - 10:43
    Check Apache's error log. Once i have installed Apache under MorphOS and it worked. In the configuration i've described here.
  • »11.04.06 - 14:06
    GK_LKA
    It writes: "No default accept serialization known!!" - What's this?
    [ GK / LKA Team ]
  • »12.04.06 - 09:35
    I've remembered i had the same thing. I don't remember how i've solved this... May be i've installed m68k Apache... Don't remember. This has something to do with forking. Probably this version also works only in inetd mode.
  • »12.04.06 - 09:50
    GK_LKA
    68k? It's more than 6 years old!
    http://www.aminet.net/package.php?package=comm/www/Apache_1.3.12.lha
    I think this new one does not run in standalone mode at all. :(
    [ GK / LKA Team ]
  • »12.04.06 - 09:59
    DJBase
    Posts: 744 from 2003/4/6
    1.3.33 runs only in inetd mode. Can't compile a new version because I don't have a MorphOS Developer machine anymore. Sorry.
  • »12.04.06 - 10:13
