Moderator
Posts: 441 from 2003/2/26
Acill,
Im posting the short text below, so You have something to read while awaiting MorphUP package
Btw, there is now 16 developers commited to Ambient, only 84 to go to 100
$Id: ambient.notes,v 1.692 2006/04/09 15:56:02 kiero Exp $
09.04.2006
- debug.c, debug.h, menu.c
ADVANCEDPREFS debug class (tokai)
- str.c, str.h
optimized hctod with nice array and static inline (piru)
- appclass.c, init.c, makefile.objs, mimetype.h, prefs.h, vars.h, prefs_advanced.c,
prefs_advanced.h
Advanced.conf support.
+ Supports for now 5 different variable types:
- string (expects string with or w/o quotes)
- bool (expects 1, true or on)
- int (decimal and hexadecimal)
- uint (decimal and hexadecimal
- colour (hex value only)
+ variables can be boottime only or changed on notify event too
See prefs_advanced.c how to add new variables and prefs_advanced.h for usage
information.
- shortcuts.c
"My MorphOS" icon is optional hidable now (tokai)
- mimetype.c
copy/move drag'n'drop operation behavior configurable with option in advanced
prefs (tokai)
- iconviewclass.c
doubleclick on desktop behaviour is now configurable over advanced prefs (tokai)
- distribution/prefs/Advanced.prefs,default
default configuration and documentation for advanced prefs options (tokai)
- makefile
release and install-iso rules modified to take care of default Advanced.conf
(tokai)
- Install
copies Advanced.conf to SYS:Prefs/Ambient if useful (tokai)
- clickpathclass.c cxlistclass.c iconclass.c iconviewclass.c listviewclass.c
prefs_advanced.c prefs_advanced.h shortcuts.c distribution/prefs/Advanced.conf,default
- CxBlackList is gone, function moved to "commodityfilter" option in Advance.conf
- "mymorphosname", temporary option to rename "My MorphOS" until itix has it done the
real way.
(tokai)
- panelgroupclass.c: final fix to panels so that frame size is taken into account
too... argh. (itix)
- listview*.c contextmenu.c
removed dynamic allocations to get deficon path, for less fragmentation.
icons displayed in device list should be the same as in icon mode now.
fixed a zeropage hit when sorting with device column.
enabled context menus in device list (rename disabled for now as it's not really functional).
pressing middle button outside of a lister just disables inline renaming. (fab1)
- windowclass.c
made window_loaduri handle "" paths (device list), which removes yet another zeropage hit with
back toolbar button. (fab1)
- sysinfowinclass.c: removed buffer overflow formatting cache strings. (piru)
- appclass.c, deficon_getpath.c, device_func.c, file_func.c, fonts.c,
iconio.c, iconviewclass.c, listviewclass.c, listviewclass_nlist.c,
movelist.c, shotcuts.c, wbstart.c, iconlib/diskobject.c, private.c:
avoid peeking memory before passed pointer if string is "". (piru)
- file_func.c: optimized is_path_contained(). (piru)
- deficon_getpath.c: fixed deficon_getpath() not to overflow the passed
buffer size. empty DefIcon_Path envvar is considered invalid and is
replaced by ENVARC:sys/ now. (piru)
- iconlib/diskobject.c: fixed getdeficon() not to overflow the passed
- iconviewclass.c fixed MM_Notify_Change NOTIFYTAG_Monitor_Device_Name
'if ( p[ len - 1 ] = ':' ) )' -bug. (piru)
- prefs_advanced.c
+ on-the-fly changeable variables are now reset to default if deactivated
+ fixed memory leak for cleanup
(tokai)
- prefswin_listerclass.c
Fixed underscore handling for mode gadget and added missing online
help strings. (geit)
- prefswin_icondisplayclass.c
Fixed color gadget label to support underscore. (geit)
- colormap.c: made faster & shorter with LoadRGB32(). (piru)
- clickpathclass.c, clickpathbuttonclass.c, clipboard.c, makelinkwinclass.c, wbstart.c:
Replaced strncpy() by stccpy(). (itix)
- wbstartlib.c, soundlib.c:
Replaced Remove() by REMOVE(). (itix)
- appclass.c, devicelistclass.c, listviewclass.c, listviewlistclass.c, navigationclass.c,
recog.c, rexx.c, viewgroupclass.c: replaced strncpy() by stccpy(), removed few dupe
strlen() calls, changed Remove() to REMOVE(). (itix)
- contextmenu.c
Added "create panel" to panel and panel item context menu. (geit)
- capacity.c: shortened code by removed superfulous strncpy(). (itix)
- fastcopy.c, findver.c, iconio.c, scandir.c, wbstartup.c: optimized threads a little by
removing syncs where not needed. (itix)
- infowinclass.c: fixed braindamaged stccpy() usage. (itix)
- textviewclass.c
fixed unwanted appending of text to view, when file gadget in clickpath was pressed.
(tokai)
- iconclass.c/icondata.h/thumbs.c/deficonpool.c
Smarter deficons support. Saves tons of memory. Faster. (kiero)
Best wishes, Gunne
