Burning Programs!
    XzIt
    Posts: 250 from 2005/1/19
    I started this post, because i need a Burning Program for MorphOS..
    I have Frying Pan and MakeCD....
    But what about BurnIT 3 ???
    Is Frying Pan the best DVD/CD Burning Program????  :-?
    Where is the FryingPan HomePage????
    Whats the current version?
    Plz reply  :-x
    XzIt Of Apathy  8-)
    PegasosII G4 @ 1Ghz MOS 1.4.5
    512MB DDR-RAM, Radeon 9200
    2x Western Digital 200GB HD
    Soundblatser Live!, Samsung 19"
    LCD Syncmaster 913V TC099 Silver
  • »21.03.06 - 14:40
    BatteMan
    Posts: 294 from 2003/2/24
    With this :
    http://www.google.com/search?hl=fr&ie=ISO-8859-1&q=frying+pan+amiga&btnG=Recherche+Google&meta=
    I found that :
    http://www.tbs-software.com/fp/
    Last update : 0.4b2 (16 March 2005) but a new version is near to come.
    If you have FP, why do you ask those questions ?
    For BurnIt, still waiting.
  • »21.03.06 - 14:49
    thefab
    Posts: 92 from 2003/8/19
    burnit3 will be released with mos 1.5.
    Frying Pan homepage
    last version: 0.4b2 from 2005
    [edit]
    BatteMan: graaaaaaaaaaa, take this: RASEEEEEENGAN!!!!
    [ Edited by thefab on 2006/3/21 17:54 ]
  • »21.03.06 - 14:52
    GK_LKA
    Posts: 481 from 2004/3/28
    Cool. At least this version of FryingPan starts and doesn't crash in 3 seconds. But... so... is anybody here who has written DVD's with it on MOS? I can't even configure my CD/DVD writers...
    [ GK / LKA Team ]
  • »21.03.06 - 15:11
    merko
    Posts: 328 from 2003/5/19
    I've just registered FryingPan and I think it's well worth it. It's
    very straightforward to set up a project to burn and frankly I did not
    expect an emulated program to burn so well on-the-fly at 6x (8MB/s).
    But I've made a few backups and had no problems at all.
    The GUI is a bit weird, but it's friendly and functional, so the only
    real gripe with me is that it's a hassle to transfer money to Poland
    (but this is not the author's fault of course).
  • »21.03.06 - 15:19
    Jupp3
    Posts: 1193 from 2003/2/24
    I did not expect an emulated program to burn so well on-the-fly at 6x (8MB/s).
    Well, probably it just uses system functions f.ex. for file access. System functions, that are fully PPC native on MorphOS, of course.
    My 060 A1200 could write a full CD in less than 10 minutes on all-IDE setup. I thought (and still think) that that was amazing :-)
  • »21.03.06 - 15:46
    GK_LKA
    How can I configure it? If I select ide.device in the drive tab, nothing appears on right in the unit dropdown list.
    [ GK / LKA Team ]
  • »21.03.06 - 15:50
    Posts: 2223 from 2003/2/24
    I'd like to know that too. I can't configure unit for ide.device and thus can't do anything useful with demo version. Can't be demo limitation? I'm not going to buy software if I can't test burning with it.
    I just bought DVD writer and seems that there isn't much working software for it... Can burn DVDs from Linux side, but would be better to be able use it on MOS.
    [ Edited by jPV on 2006/3/21 20:22 ]
  • »21.03.06 - 16:20
    thefab
    the bug of the empty device list appeared with mui4 alpha, i guess you can just boot from a morphos cd, select your device, then reboot, or downgrade to mui 3.9 :)
    this bug should be corrected with the next beta i guess
  • »21.03.06 - 16:34
    Tested with some old MOS without mui4alpha and it seemed to work. Drive info was recognized, but then it didn't recognize inserted media. Media info said always no disc... maybe needs more testing :)
  • »21.03.06 - 17:32
    GK_LKA
    I've tried with MUI3.9, and could select the correct drives. But... I've tried to write or format disks, but nothing seemed to work. The drive starts to format, but it formats for eternity... The write button didn't do anything. Shall it work, is only my system bad...?
    [ GK / LKA Team ]
  • »21.03.06 - 17:59
    Posts: 1087 from 2003/3/24
    Cool, can't wait for the new FP release. And that Software rocks.
    I use Frying Pan since a year or longer and i am very satisfied with it.
    Many thanks to Tomasz!!!
  • »21.03.06 - 20:23
    GK_LKA
    Hm... I think I found the answer:
    "Q:  What are the restrictions of demo version? Can I burn anything with it?
    A: No, actually not. Version 0.4 will no longer let You write data in real mode; instead drive will make an attempt to burn Your discs in test mode. Another limitation is that reading & writing is limited to a minimum speed. This restrictions include burning, erasing and other actions that will modify Your CD / DVD contents as well as any action that will access your drive in any way, even speed probing.
        As far as the demo version does not allow You to burn data to disc, You still can use it as data extractor. For more information concerning this topic check other subpages on this site :)."
    (From the offical home page)
    [ GK / LKA Team ]
  • »22.03.06 - 12:59
    GK_LKA
    Finally got it working - and I'm very satisfied with the program. Works very fine. :))
    [ GK / LKA Team ]
  • »05.04.06 - 12:56
    r-tea
    Posts: 321 from 2005/3/27
    @ merko
    The GUI is quite good. Maybe a little "overfed" :) Simple buttons (with small images) would be enough.
    The biggest lack of FryingPan IMHO is the lack of a CopyCD/DVD option.
    The autor have just said to me that there woun't be such an option :( but, fortunately, he plan to make a separate tool with this end in view.
  • »05.04.06 - 13:49
