Bootpic no more
    Mi-Go
    Posts: 95 from 2003/9/18
    which libraries are loaded during boot right after the kernel?
    I used to have a nice logo but now, after updating ambient and playing around a bit, I have just some corrupted green lines on top of my boot menu.
    MorphOS cd boots fine, so I think it's a sw issue.
    It's no big deal, but thanks for any help :-)
    M.
    (BTW the problem is the same regardless of monitor tooltypes)
  • »20.03.06 - 00:45
    Bladerunner
    Posts: 418 from 2004/2/19
    One of those (many) known problems with Mui 4.0 Alpha.
  • »20.03.06 - 00:48
    Mi-Go
    Cool ;-)
  • »20.03.06 - 00:54
    Toto
    Posts: 268 from 2003/4/20
    There is an easy fix. Go to settings and select a screenmode for Ambient, save and reboot. Your bootlogo is back again :-)
    -toto
  • »20.03.06 - 01:23
    SoundSquare
    Posts: 1214 from 2004/12/1
    @Toto
    this doesnt' work for me
    I noticed that if i change my screenmode resolution (1280x1022 instead of 1280x1024 for example) then the bootpic gets back.
    weird.
  • »20.03.06 - 07:57
    Toto
    @SoundSquare
    Actually, another thing I did to get the bootpic back; I removed all my screenmodes in modeedit and selected new ones. After that I seleceted a new screenmode for Ambient and the bootpc was back again.
    Every time I change skins the bootpic is lost again and I have to repeat the step in my previous post to get it back again.
    ~toto
  • »20.03.06 - 08:41
    Mi-Go
    Toto wrote:
    @SoundSquare
    ~toto
    maybe that's why it showed up so late: it was ages since I last changed my ambient skin...
    I'll try your fix.
    Thanx
  • »20.03.06 - 09:25
    SoundSquare
    deleting sys:prefs/envarc/publicscreens.prefs and reboot should work too.
    it solves it only for the first reboot, but once you select a screenmode again then back to the beginning.
    deleting all screenmodes and recreating them works here apparently.
  • »20.03.06 - 19:25
