Samba version and setup.
    matt3
    Posts: 785 from 2004/2/10
    Which Samba version do you use? Should I use the MOS version (alpha) or the AOS release version. Seems like file locking may not be complete in the MOS version.
    I will be using it to share my peg 2 with my pc's full time. My peg uses MOS net version 1 with DHCP (Nice release!).
    I have the x-surf setup config and start samba utilities as well.
    Any setup tips would be very much appreciated.
    Thanks,
    Matt
    [ Edited by matt3 on 2006/3/14 13:40 ]
  • »14.03.06 - 16:20
