Moderator
Posts: 441 from 2003/2/26
Taken from the Ubuntu wiki:
By default, the password for root is locked in Ubuntu. This means you cannot login as root or use su. Instead, the installer will setup sudo to allow the user that is created during install to run all administrative commands.
This means that in the terminal you can use sudo for commands that require root privileges. All programs in the menu will use a graphical sudo to prompt for a password. When sudo asks for a password, it needs YOUR password, this means that a root password is not needed.
Read more hereThey do have an excellent wiki at www.ubuntu.com
Edit, I see now I was little late there
Gunne
[ Edited by gunne on 2006/3/3 1:24 ]
Best wishes, Gunne
