linux on pegasos1
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    I guess with the recent server crash, my thread asking about linux (debian) on pegasos1 went missing.
    So here I am asking again. Anyone who has installed linux sucessfully on peg1 perhaps can post here and tell me the secret to how they got linux installed on the peg1.
    Installation from either the CDs sven sent me (and the recent netinstall iso downloaded from his site) seem to go fine, what I get stuck on is copying the kernel from the installed partition to the FFS partition where the other boot.img's reside.
    The readme for the pegasos1 states that during the installation to drop to a shell by pressing alt-f2, type in some commands to make an FFS partition then type this..
    # mkdir /boot
    # mount -t affs /dev/ide/host0/target0/lun0/part1 /boot
    # cp /target/boot/vmlinuz-2.4.27-powerpc /boot
    # umount /boot
    For whatever reason, this never works and I get errors such as 'file or directory not found'.
    Its a shame that a utility or script to copy the kernel from the install to the FFS partition wasn't included.
    The OF in the peg1 seems to be only able to recognise FFS partitions, although I've seen mention of it possibly being able to read FAT partitions.
  • »19.02.06 - 05:27
    ironfist
    Posts: 254 from 2004/4/22
    What do you see if you type:
    ls /
    Or, did you TAB this line:
    Also type df to see if you really mounted /boot.
  • »19.02.06 - 08:35
    SoundSquare
    Posts: 1214 from 2004/12/1
    i suppose you haven't got time to read the answers we gave you before the server crash.
    you'd better use ext2Filesystem and mount your linux partition under MorphOS. So you'll be able to copy your kernel into your FFS boot partition and boot on it. I can't think of anything easier.
  • »20.02.06 - 12:03
    Posts: 98 from 2004/6/4
    First of all check if /boot already exists. the kernel might be already there and when you mounting /dev/hda1 to it you automatically see only files on /dev/hda1.
    Try this
    mkdir /mnt/boot
    mount /dev/hda1 /mnt/boot -t affs
    and then if your /boot contains the kernel then
    cp vmlinuz-(I dunno the version)-powerpc /mnt/boot
    else
    cp /target/boot/vmlinuz-(I dunno the version)-powerpc /mnt/boot
    umount /mnt/boot
    You should place the correct version instead (I dunno the version) line.
    WBR, Vladimir Berezenko
  • »21.02.06 - 06:27
  • News Moderator
    News Moderator
    Darth_X
    OK, I figured out that it helps if you manually partition the hard drive and ensure that a / and a /boot partition are set up.
    So I did get linux *partially* installed and was able to cp the kernel intl the FFS partition.
    Now I need to figure out how to fix the broken installation, if it can be done without just formatting, repartitioning and re-installing yet again.
    Compared to Windows and morphos, linux is the most difficult operating system I have ever attempted to install.
  • »23.02.06 - 11:30
  • News Moderator
    News Moderator
    Darth_X
    maybe an extra /boot isn't needed, as the FFS partition is already /boot
    OK, with partitions set up, installation goes fine, the kernel gets copied to to the FFS partition manually, but when I reboot and continue the installation I keep getting 'packages fail' when I use the DVD-Rs sent to me :/
    argh!
    I can however log into root or my user. Maybe I can try to download the packages?
    So maybe aptitude can be used, but if I select something like KDE it says it will use 4.2GB of hard drive space.. hmmm! I probably don't want to install the whole thing then. :-D
    [ Edited by Darth_X on 2006/2/23 6:36 ]
  • »23.02.06 - 12:50
    ironfist
    Linux is hard for any novice who doesn't read documentation or
    choose a distro with bad documentation written. I can't say
    Debian is a good distro if you need documentation on how to
    set up your Pegasos. The Gentoo installation is however very
    easy - follow the Gentoo PPC Installation Handbook. Every
    Pegasos-specific actions are there aswell.
    Someone should really make some documentation for Debian
    and Ubuntu since they are quite popular Pegasos-distros..
  • »23.02.06 - 17:34
  • News Moderator
    News Moderator
    Darth_X
    whew! It took a long time to figure things out, and a lot of blind guesses (I know I should have read ALL the documentation in the first place, but that would have taken hours in itself!) but I have eventually got linux installed. Its not a perfect install and I will probably have to fix things, but for the most part I have a xfce running some apps. nice! :-D
  • »23.02.06 - 22:39
    judas
    Posts: 175 from 2005/1/14
    I managed to install debian with the peg1-bootCD.
    What I don't like is, that everything gets downloaded from inet.
    Is there some way to offline-install with this CD ?
    bye
  • »24.02.06 - 06:44
    Snuffy
    Posts: 58 from 2005/12/4
    I got Sarge installed on this A1 by setting the preferences in
    etc/apt/sources.list
    You use "apt-cdrom add" in bash to set this file. I had 14 CDs
    to setup this way for an "apt-get update apt-get upgrade".
  • »27.02.06 - 04:25
    magnetic
    Posts: 2129 from 2003/3/1
    Snuffy
    Yes. Good post :-)
    @Judas
    You dont have to select all the packages for internet download. You can do just a base install and then apt-get whatever you ned. You can use deselect also do deselct apps that get installed. But this question is better suited to ppczone.org not morphzone.
    magnetic
  • »27.02.06 - 04:50
