Problem creating mountlists
    winterhunter
    Posts: 204 from 2005/10/13
    Hi everyone,
    I've downloaded the ext2FS driver to be able to read my linux
    partition, and I'm now trying to mount it.
    I've followed the instructions that come with ext2fs:
    + copy the driver to L:
    + create a mountlist with giggledisk
    + modify the mountlist
    + run mount, or copy to devs:dosdrivers
    Well it just doesn't work. Mount tells me:
    Ram Disk:> mount LNX: debug
    Mount: Current DevName <LNX:>
    Mount: search for devname <LNX:>
    CheckDevice: <LNX>
    CheckDevice: object doesn't exists
    ReadMountList: find <LNX> in mountlist <lnx>
    ReadFile: <lnx>
    ParseMountList: <LNX>
    ParseMountList: buffer <FileSystem>
    ParseMountList: ReadItem res 1
    ParseMountList: failure
    ERROR: Device 'LNX:' not found in file 'lnx'
    Mount: failed with error 5001
    In the bottom of this post I'l put ther original (giggledisk) and
    modified mountlists.
    BTW, when I mount SMBFS: (samba), Ambient does not display an Icon. I
    was told it was probable a prob with mosnet, but the same happens with
    miami and genesis. There is a disk.icon present in the target drive.
    How can I declare that a new device was mounted so ambient notices?
    Besides that, SMBFS works just fine.
    Any ideas?
    Thanks!
    Original mountlist
    ** DosDriver automatically created by GiggleDisk
    ** GiggleDisk (c)2005 Guido Mersmann
    FileSystem = L:EXT2FileSystem
    Device = ide.device
    Unit = 0
    BlockSize = 512
    Surfaces = 1
    SectorsPerBlock = 1
    BlocksPerTrack = 9541
    Reserved = 2
    PreAlloc = 0
    Interleave = 0
    MaxTransfer = 0x00FFFFFF
    Mask = 0xFFFFFFFF
    LowCyl = 9018
    HighCyl = 16382
    Buffers = 30
    BufMemType = 0
    StackSize = 16384
    Priority = 0
    GlobVec = -1
    DosType = 0x4C4E5800
    Activate = 1
    Mount = 0
    /* Bootable = FALSE */
    Modified mountlist
    Device = ide.device
    Unit = 0
    BlockSize = 512
    Surfaces = 1
    SectorsPerBlock = 1
    Reserved = 2
    PreAlloc = 0
    Interleave = 0
    Mask = 0xFFFFFFFF
    LowCyl = 9018
    HighCyl = 16382
    Buffers = 128
    BufMemType = 0
    StackSize = 16384
    Priority = 0
    GlobVec = -1
    DosType = 0x45585432
    Activate = 1
    Mount = 0
  • »19.02.06 - 14:27
    Toto
    Posts: 268 from 2003/4/20
    If you rename your mountlist from LNX to LNX0 it should work.
    ~toto
  • »19.02.06 - 15:11
    March
    Posts: 91 from 2003/7/30
    If your mountlist is in RAM: use following:
    cd ram:
    mount LNX
    (without colon after device name).
    Marek Szyprowski ...... happy MorphOS, AmigaOS and Debian/Linux user ........
  • »20.02.06 - 07:31
    Otti
    Posts: 20 from 2004/3/31
    I gave that Mountlist an Projekt-Icon
    default Programm: MorphOS:MorphOS/c/Mount
    Tooltypes: DEVICE=ide.device
    UNIT=0
    ACTIVATE=1
    from now I could start mounting with an doubleklick
  • »20.02.06 - 09:17
    winterhunter
    I've tried to rename it to LNX0, and mount it without the ":" and it
    does not work (see results at the end of the post).
    I've also copied the mountlist to DEVS:Dosdrivers/ to try to automount
    it during boot, but I get an error.
    Any other ideas?
    Ram Disk:> mount LNX0 from RAM:LNX0 debug
    Mount: Current DevName <LNX0>
    Mount: search for mountfile <LNX0>
    Mount: Changed directories...
    Mount: try File <Ram Disk:LNX0>
    ReadMountFile: <Ram Disk:LNX0>
    ReadMountFile: mount <LNX0>
    CheckDevice: <LNX0>
    ReadMountFile: readfile
    ReadFile: <Ram Disk:LNX0>
    ReadMountFile: preparsefile
    ReadMountFile: parsemountfile
    ParseMountFile:
    ReadArgs..
    FileSystem = L:EXT2FileSystem Device = ide.device Unit = 0 BlockSize = 512 Surfaces = 1 SectorsPerBlock = 1 BlocksPerTrack = 9541 Reserved = 2 PreAlloc = 0 Interleave = 0 MaxTransfer = 0x00FFFFFF Mask = 0xFFFFFFFF LowCyl = 9018 HighCyl = 16382 Buffers = 128 BufMemType = 0 StackSize = 16384 Priority = 0 GlobVec = -1 DosType = 0x45585432 Activate = 1 Mount = 1
    ReadMountArgs:
    ReadMountArgs: ReadArgs failed
    ReadMountArgs: bad template
    Parse: ReadArgs failed
    ReadMountFile: parsemountfile error 5002
    Mountfile 'Ram Disk:LNX0' is invalid: bad template
    Mount: failed with error 5002
  • »21.02.06 - 06:18
    Toto
    Maybe it's your DosType value, it's supposed to be 0x4C4E5800 just like in your GiggleDisk mountlist.
    Here's my mountlist:
    Device = ide.device
    Unit = 1
    BlockSize = 512
    Surfaces = 1
    SectorsPerBlock = 1
    BlocksPerTrack = 9771
    Reserved = 2
    PreAlloc = 0
    Interleave = 0
    MaxTransfer = 0x7FFFFFFF
    Mask = 0xFFFFFFFF
    LowCyl = 1
    HighCyl = 4177
    Buffers = 256
    BufMemType = 0
    StackSize = 16384
    Priority = 0
    GlobVec = -1
    Activate = 1
    /* Mount = 1 - MorphOS is not supporting this value */
    I've set it up in Devs/DOSDrivers as LNX0 with the same tooltypes as Otti. My Ubuntu partition won't mount if it's called LNX instead of LNX0.
    ~toto
  • »21.02.06 - 11:49
    winterhunter
    @Toto: Thanks a lot, I'll try changing the DosType and commenting the "mount = 0" line.
  • »21.02.06 - 12:46
    winterhunter
    @Toto: Thanks a lot, it now works. Commenting the "mount" did the
    trick.
  • »21.02.06 - 18:30
