Screensavers - suggestions ?
    koan
    Posts: 303 from 2005/11/21
    Hi
    What are people doing for screensavers these days ?
    I'm still using a CRT so I think I should install one.
    thanks
    koan
  • »17.02.06 - 13:02
    hooligan
    Posts: 1948 from 2003/2/23
    four letters: dpms
  • »17.02.06 - 13:23
    guruman
    Posts: 462 from 2003/7/21
    A DPMS blanker should be included in MorphOS 1.5... In the meanwhile you can use blanky, a MorphOS commodity from Alfie, that supports DPMS: get it here.
    Kind regards,
    Andrea
  • »17.02.06 - 13:40
    Toto
    Posts: 268 from 2003/4/20
    Blanky works fine. There's also a MOS version of Matrix blanker (Aminet) wich supports DPMS.
  • »17.02.06 - 14:00
    koan
    Thanks for the help.
    I just downloaded both blankers,
    the aminet one is here : Matrix.lha
    koan
  • »17.02.06 - 14:06
    Phantom
    Posts: 381 from 2004/9/7
    I advise you to buy a TFT-LCD monitor...they are cheap now and it's better for your eyes  8-)
  • »17.02.06 - 15:50
