SMBFS
    winterhunter
    Posts: 204 from 2005/10/13
    Hi everyone,
    I'm using SMBFS to share data between my linux box and my peg, and would like to ask you a question:
    Is there some way (through a script, I guess) to launch SMBFS (which mounts a SMBFS: volume) and then force ambient to display a volume icon?
    Thanks!
  • »18.01.06 - 07:54
    hooligan
    Posts: 1948 from 2003/2/23
    Yes. Just make a script and an icon for it, and put it to Ambient Panel or create a shortcut on Ambient. Or why not just add the command into user-startup so it will be mounted on every boot?
    As for the icon, just copy a disk.info onto your samba-device. That takes care of it. Creating def_icon def_smbfs might also work.
  • »18.01.06 - 08:41
    winterhunter
    I've tried it but id doesn't work. But that does not surprise me...
    As a matter of fact, if no disk.info is present, ambient should have used the default disk icon present in RAM:ENV/sys/. However, it doesn't.
    It looks more like Ambient is not "notified" that a new device is present. So my question stands: is there any way of FORCING ambient to show an icon that links to a volume/drawer/whatever?
  • »18.01.06 - 11:50
    dIGIMAN
    Posts: 273 from 2005/11/7
    Winterhunter, looks like u got smbfs to work :)
    Had the same problem under wb 3.9, as the
    device gets mounted when ambient/workbench is already up.
    Ive just put
    path smbfs: ((or ur volumename of the linux share)
    in the script.
    if this doesnt work try even
    diskchange smbs:
    Havent tried under ambient yet but this worked for 3.9....
  • »18.01.06 - 11:54
    Bladerunner
    Posts: 418 from 2004/2/19
    Winterhunter:
    Are you sure you have configured smbfs correctly? I am using it since ages (meaning pre Ambient GPL) and it works without Problems. (And yes, if there is no disk.info icon, it will use the default one)
    I made a script which launches two instances (two machines)
    here is how it looks like (just for one machine, but you get how it works ;) ):
    Run >NIL: SMBFS Workgroup=KRASSLAN User=username Password=xxxxx Volume=Cerberus Service=//CERBERUS/C
    xxxx is of course your password ;) Please note that afair indeed the machines name is needed (or was that for Rdesktop?) and not the IP.
    Oh and which TCP Stack do you use?
  • »18.01.06 - 12:35
    winterhunter
    @dIGIMAN:
    Thanks for the info, I will try it tonight.
    @Bladerunner:
    I'm sure it works, I've moved 30 GB of data from my linux partition to my peg using SMBFS in the commandline; DOpus 4.17 does not like SMBFS and tells me that the source files are write-protected which they aren't (besides, I was using the copy function, not move, so what should it care about the source files being protected or not).
    I'm using MOSNet 0.17.
  • »18.01.06 - 12:57
    Bladerunner
    Well, try another stack then.
    If even Dopus complain...
    It happens that I also use Dopus and at least there everything should be ok. So I assume (given that you configured smbfs correctly) that it`s MOSnets fault. Here it works ok with MiamiDX or Genesi.
  • »18.01.06 - 13:11
    winterhunter
    If it is stack-related, shouldn't I have problems transfering data? I mean, CLI copy, dir, delete, etc. works just fine.
  • »18.01.06 - 13:29
    hooligan
    I use MiamiDX, and got no problems with SMBFS. I have disk.info on my servers root and when I mount them I immediately get drive-icons on Ambient.
  • »18.01.06 - 14:12
    winterhunter
    @dIGIMAN:
    It didn't work, neither path nor diskchange!
    @All:
    I've forgot to mention it, but I'm running the "old" ambient (the
    official that comes with MOS 1.4.5... Maybe that changes something?
  • »18.01.06 - 16:29
    hooligan
    @Winterhunter
    I don't think so, I have had my smb-scripts for a long long time. From MOS1.3 at least.
  • »18.01.06 - 17:59
    hooligan
    @Winterhunter
    Oh, btw, to end your hunt:
    http://de.fishki.net/picsn/mail/gradusniki.jpg :-)
  • »18.01.06 - 18:01
    Bladerunner
    Winterhunter: Same here, As I allready said, I have SMBFS running since ages. Also Dopus works actually fine. Really, try anothter Stack and see whats happening.
  • »18.01.06 - 19:53
    todi
    Posts: 140 from 2003/2/18
    @winterhunter
    SMBFS volumes on ambient don't work with the mos1.4.5 release. I had the same problem and got one of the developers (itix) to fix it for me. So it should work in newer versions! :)
    Btw. same goes for NFS mounted devices!
    [ Edited by todi on 2006/1/19 0:48 ]
    ToDi
    amigazeux.org
  • »18.01.06 - 22:46
    winterhunter
    todi wrote:
    @winterhunter
    Do you mean newer Ambient (like the recent CVS compilations) or newer MOS? (That is almost a trick question ;-))
    BTW, I've noticed (with task manager) that I have some processes running (even when the devices are not mounted):
    CD0, DH0, DH1, DH2, USMD
    So, one process corresponding to each drive. But no process for SMBFS... So I was wondering whether I had to declare SOMEWHERE that a device called SMBFS will arrive (like a linux mount list).
  • »19.01.06 - 07:33
    todi
    Newer version of ambient of course. ;-)
    All I do is run smbfs for the volumes I want, like what Bladerunner wrote earlier. No 'mountlist' needed.
    ToDi
    amigazeux.org
  • »19.01.06 - 19:49
