Speeding up the pegasos cd32-kernel.
    CISC
    Posts: 619 from 2005/8/27
    If you, like me, has gotten the new cd32-kernel and noticed that some games were stuttering and not all up to speed, this might help (depending on the game). ;)
    If the game in question is lowres only (if you change gfx_linemode to scanlines in the uaerc you'll easily notice if it's hires or not) you can improve the speed quite abit by changing to these options:
    gfx_width=512 (this one is obsolete, you might as well comment it out)
    gfx_height=384 (this one too)
    gfx_width_windowed=512
    gfx_height_windowed=384
    gfx_width_fullscreen=512
    gfx_height_fullscreen=384
    gfx_lores=true
    gfx_linemode=none
    gfx_colour_mode=32bit (this one probably has no impact either way, but I prefer it over 16bit. ;) )
    Now you should have a quite snappy emu, but if the game employs any hires gfx the quality will be rather bad.
    (you might also want to change the kbd_lang option, unless you are german (kbd_lang=us should work for most gameplay (no more misplaced Z)). ;) )
    ..I've noticed that any other linemode than none seems to slow down EUAE alot, and I really don't see any reason why it should, I suspect it's some kind of bug (or horribly bad code), guess I (or someone else if you want it fixed ASAP. ;) ) should take a look some day... :P
    Additionally EUAE halts the game whenever it changes CD-audio tracks, this can be devastating to gameplay (like f.ex. in Pinball Illusions, where you'll quite easily lose a ball due to this), I have no idea if this is EUAE's or Linux's fault, but this is another thing that might be a good idea to investigate. ;)
    - CISC
    [ Edited by CISC on 2006/1/18 16:10 ]
  • »18.01.06 - 14:59
    magnetic
    Posts: 2129 from 2003/3/1
    Thx CISC
    I'll have to give this a shot. I have a couple of CD32 titles here somewhere..
    :-D
    magnetic
  • »19.01.06 - 11:03
