Cd Emulator!
    XzIt
    Posts: 250 from 2005/1/19
    Is there a CD Emulator tool for MorphOS???
    So you can "Mount" ISO files, like a cd?
    Would really be great to have....  8-)
    Hope someone wants to do something about it!
    XzIt Of Apathy
    ATH
    ***Click  :-D I love Ncomm
  • »14.01.06 - 12:45
    analogkid
    Posts: 711 from 2004/11/3
    this one works for me: http://www.aminet.net/package.php?package=disk/misc/diskimage.lha
    [ Edited by analogkid on 2006/1/14 15:08 ]
  • »14.01.06 - 13:08
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    If you use DOpus you could install the xad.module. Then you can access the files in the iso as it would be a directory and not an image...
  • »14.01.06 - 13:30
    XzIt
    But do i need Opus5? i only run 4  8-)
    X
  • »15.01.06 - 14:40
  • pOS
    pOS
    Yes, you would need Ops5. opus4 and 5 are two quite different tools. The first one is a simple filemanager, the second one a complete Desktop environment (the most powerful I know of...).
  • »15.01.06 - 18:43
    Chain-Q
    Posts: 350 from 2003/10/12
    The thing on the URL in analogkid's post works nicely for me. However, it only worked for me with an external CDFS, not the internal one. If someone have a few hints how to make it work with the internal CDFileSystem, share plz.
    [.Hosting AmigaSpirit.hu.]
  • »16.01.06 - 10:17
    analogkid
    I tried to create a dosdrivers from MakeMountlist's output.
    But for CD0: is says:
    CD0:
    Priority = 10
    StackSize = 4096
    GlobVec = -1
    Startup = 0x134633687
    which is not very helpful, I think.
  • »16.01.06 - 10:43
