Samba
    winterhunter
    Posts: 204 from 2005/10/13
    Hi everyone,
    I was just trying to install Samba with MOSNet, and the instructions
    say to add some executables to the inetd.conf... since MOSNet does not
    have an inet daemon configuration named so, I was wondering if anyone
    could tell me how to configure it correctly.
    Thanks!
  • »08.01.06 - 16:34
    Fizzy
    Posts: 23 from 2005/12/22
    As its still very much a "work in progress" I doubt that the functionality is available yet to support samba. I'm sure I've read that inetd is not implemented yet...?
    I'm just greatfull that I can get online now without being disconnected every 30 mins.. ;o)
  • »08.01.06 - 16:57
    analogkid
    Posts: 720 from 2004/11/3
    according to Sonic, 68k inetd should work. But I haven't managed yet to get it work.
  • »08.01.06 - 17:30
    winterhunter
    In the thread below there are some results using smbfs:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=4255&forum=32
  • »08.01.06 - 17:37
    dIGIMAN
    Posts: 273 from 2005/11/7
    You dont need inetd for smbfs as its only a client.
    For Samba itself u need inetd.
    I have no problems using samba & mosnet.
    i am running the inetd that was included in amitcpv4.3 after going online in the startnet script.
    Its important for inetd amitcp that the assigns exist
    for example amitcp:db/inetd.conf
    Best thing is to Assign AMITCP: MOSNET:
    and put the directorys there.
  • »09.01.06 - 11:26
    winterhunter
    Two questions:
    Where can I get amitcp v4.3? (if possible to get it?)
    I've tried to connect to a WIN XP64 computer, using:
    smbclient -L hostname -U%
    and get this error message:
    NT_STATUS_DUPLICATE_NAME
    Any ideas what this means?
    Thanks!
  • »09.01.06 - 17:29
    dIGIMAN
    You only "need" Samba if u want to share ur data on the amiga to the network.
    If u only want to connect from amiga to other samba/windows machines, smbfs does a real good job on my machines.
    U also have to enable plain password over network for third party smb protocols (Dont know the exact sentence) on all ur windows machines,
    u want to access.
    Do this with gpedit.msc on ur win machines
    http://main.aminet.net/comm/tcp/smbfs.readme
  • »10.01.06 - 09:25
    winterhunter
    @dIGIMAN:
    Thanks for the info. I've read the smbfs readme that you linked, and I don't think it will work, since it tells you to use "smbclient -L host" to lookup the shared host services. Since smbclient gives me this error...
  • »10.01.06 - 12:08
    dIGIMAN
    Thats to find out the shares but as its ur pc, u should know the shared folders
    For example C$ is an share that is default on all Windows machines accessing the C drive.
    Here is my smbfs line:
    run >NIL: samba:bin/smbfs Workgroup=**** user=****** password=**** service=//pc2/c$ devicename=PC2_C
    ofcourse ur have to type in ur workgroup, the username/password of ur windows admin account.
    pc2 can be replaced by the ip adress of ur pc or enter it under etc:hosts
    On XP its possbile to have accounts without Password. These have network access dissabled...
  • »10.01.06 - 12:38
