Miami vs MOSNet
    winterhunter
    Posts: 204 from 2005/10/13
    Has anyone compared the performance of Miami vs MOSNet for simple
    uploads/downloads?
    On my computer, Miami seems to be around 20-30% faster for NNTP.
    Another question, is it still possible/worth it to register Miami?
    Thanks!
  • »07.01.06 - 04:56
    analogkid
    Posts: 720 from 2004/11/3
    For me, MOSNet is slightly faster than MiamiDx (FTP-Transfers from PC to Peg --> ca. 3 MB/s)
    And no, it isn't possible to register Miami anymore. The author has retired from Amiga market long ago.
  • »07.01.06 - 06:42
    Robin
    Posts: 741 from 2003/2/24
    Miami and Genesis are said to work faster than MiamiDX.
    So taking DX to compare to is not really the best choice ...
  • »07.01.06 - 08:16
    Posts: 1932 from 2003/10/19
    I havent done any transfers over my local network from the Pegasos to my Macs but on the internet downloading files MiamiDX is much faster. I get about 40% faster downloads using Miami over MOSnet. As an example I downloaded a podcast using MiamiDX and averaged 150 to 200k/sec but the same file never got above 80k/sec using MOSnet.
  • »07.01.06 - 11:52
    tokai
    Posts: 1289 from 2003/2/25
    ftp transfers are a bit useless for speed testing, it seems.
    for the very same file I need with ftp 116 seconds (3161722 bytes/s), but with smbfs only 58.29s (transfer mac->peg, miamidx). Thats around double speed with smbfs.
    In the other direction ftp is a lot faster... only get 80kb/s with smbfs, but >6000k/s with ATC (peg->mac, miamidx).
    I have no explanaition for this though. ;)
    regards,
    tokai
  • »07.01.06 - 15:08
  • Targhan
    Posts: 2833 from 2003/2/7
    Registering for Miami or MiamiDX is no longer possible. The point is almost moot, in all honesty. Genesis from H&P would be a better test subject (assuming the Genesis CD is still available as a stand alone product).
    :idea:Targhan
  • »07.01.06 - 16:44
    You are right Targhan but I could never get Genesis working well. So I have MiamiDX since I paid for it so long ago I use it.
    Its still strange that the new stack is so close to 80/k sec for everyone. I wonder if something in the code is dong that?
  • »07.01.06 - 23:45
