Ghostscript printing from IBrowse
    amigakit
    Posts: 44 from 2005/8/24
    Hi Everyone!
    I have installed GS850 on a Pegasos II with MOS 1.4.5. Ghostscript is the '020 version (NOFPU)
    It has been assigned (4 assigns) and Turboprint references it under the 'PS' tab.
    The gs-handler has been put in the L directory and the PS: device has been put into DEVS:DOSDRIVERS
    When I print from Turboprint from IBrowse, a small Ghostscript Window opens as per on Classic Amigas and then the Pegasos freezes and locks up.
    Can anyone help me?
    Many thanks!
    www.amigakit.com - Amiga store
  • »01.01.06 - 12:23
  • mk
    mk
    Posts: 72 from 2004/5/24
    Saerch the old another Thread over GS on Peg.
    AFAIK GS 8.50 is not ready yet.
    GS <8.50 (8.30?, I siting not on me Peg yet) print (Canon BJC210) from IBrowse 2.3 at Peg2/G4 (MorphOS1.4.5) without Problem, but not in color.
  • »03.01.06 - 17:00
    magnetic
    Posts: 2129 from 2003/3/1
    Contact Gunne @ GGS Data - iirc he is running this setup.
    magnetic
  • »03.01.06 - 18:02
  • rms
    rms
    Posts: 604 from 2004/11/27
    @ amigakit
    I use GS850 every day, professionnaly, it works without any problems at all for printing in bw or in color, via PS:, for ps2pdf conversion etc. I never had a problem with this port.
    Under MorphOS only use the 020 nofpu version, the others do not work!
    Here are the the assigns I have:
    ;BEGIN Ghostscript850
    Assign GS850: "System:GS850"
    Assign GS850Fonts: "System:GS850/fonts"
    Assign GS850Data: "System:GS850/lib"
    Assign GS850Resource: "System:GS850/resource"
    Assign Ghostscript: "GS850:"
    ;END Ghostscript850
    The gs-handler (1664 bytes) is in L: and PS: is in Devs/DOSDrivers.
    My command line in Turboprint's PS tab is:
    GS850:bin/gs -sDEVICE=tp8g -dBATCH -dNOPAUSE -q
    The Temp directory is T:
    You can also use Michael Merkels GS8gui.lha which is available on Aminet.
    Hope this helps...
    Regards
    Christoph
  • »04.01.06 - 05:52
  • mk
    mk
    > rms
    > I use GS850 every day ...
    > ... in color, via PS ...
    > ... -sDEVICE=tp8g ...
    tp8g is only for 256 SHADES OF GRAY TURBOPRINTING,
    for Color use: -sDEVICE=tp24
  • »04.01.06 - 07:13
  • mk
    mk
    > rms
    is false, use:
    assign Ghostscript: GS850:bin
    Ok, gs850 work yet with the last revision, but IBrowse print not in color, only gray.
  • »04.01.06 - 07:32
  • rms
    rms
    @ mk
    Yes, right tp8g is gray only but as I sayed I use several printers, like an Epson Stylus Color 3000, Epson Stylus C84, etc. and with these I use tp24 instead of tp8g which is for the Laser printer.
    You are also right with the assign you propose, I use a special program from the author of GS850 and that's why I have a different assign.
    And AFAIK only as per the upcoming version of IBrowse which is 2.4, printing in color will be possible.
    Regards
    Christoph
  • »04.01.06 - 12:43
