Toad : can't make it work
    winterhunter
    Posts: 204 from 2005/10/13
    Dear all,
    Firstly, happy new year!
    Secondly, I can't get toad to work.
    I get the following message:
    ARexx is not running and rxs was not able to start RexxMast.
    Any ideas?
  • »01.01.06 - 18:06
    SoundSquare
    Posts: 1214 from 2004/12/1
    yeah, as i know you're french, check it out :
    "ARexx
    ARexx, puissant système de script, n'est pas fonctionnel à 100 % dans MorphOS 1.4.x. Il suffit de renommer le fichier MOSSYS:Libs/rexxsyslib.library en quelque chose d'autre puis de copier la version 68k de ce fichier dans MOSSYS:Libs/.
    La version 68k est disponible notamment dans l'AmigaOS 3.9.
    Ensuite, ne pas oublier d'activer ARexx, en ajoutant par exemple la ligne MOSSYS:C/RexxMast >NIL: dans votre user-startup. Attention à ne pas mettre Rexxmast dans votre WBStartup."
    taken from http://wikipeg.free.fr/ french pegasos dedicated wiki. Your place for informations.
    cheers
  • »01.01.06 - 18:27
    winterhunter
    Merci beaucoup pour l'info... Je vais essayer de trouver la blibliothèque rexx quelque part...
  • »02.01.06 - 07:47
  • Targhan
    Posts: 2833 from 2003/2/7
    Sorry I am stuck replying in english ;-) SoundSquare should have gotten your exact error fixed; however, there will eventually be a new version of Frogger that will not need "Toad" anymore. (I'm unsure when a release date is planned by our friendly developer, but I know he has worked on a new frogger!!)
    :idea:Targhan
  • »03.01.06 - 17:14
    Robin
    Posts: 741 from 2003/2/24
    W O W ! This is really great news :-)
  • »03.01.06 - 17:30
  • Targhan
    @Robin:
    It might be worth bugging the author about (particularly if you have registration money!). I also have seperated out my "framegrabber" from Toad for use with the new version of FroggerNG whenever it should be released.
    @everyone:
    Due to the nature of shareware, please don't beg unless you are ready to register the newer version. :-D
    :idea:Targhan
  • »03.01.06 - 17:43
    Robin
    I've bought a keyfile the first time
    and I'll buy it again :-D
    And I really hope it comes with the skins that
    were shown here in the old gallery(*G* hint :-D )
  • »03.01.06 - 18:33
  • Targhan
    indeed.
    that also reminds me I need to work on the new gallery some more...
    :idea:Targhan
  • »03.01.06 - 19:03
