Harddisks on MorphOS
    XzIt
    Posts: 250 from 2005/1/19
    How do i get Both the Linux disk and MacOS disk to show on MorphOS?????
    Would really like 2 know how u guys did it.  :-D
    XzIt Of Apathy  8-)
  • »25.12.05 - 17:43
    Wishmaster
    Posts: 342 from 2003/6/29
    Use a Filesystem, which is supported by MorphOS.
    Then you can create a Mountfile with Giggledisk and mount it.
    Pegasos PPC
  • »26.12.05 - 14:22
    magnetic
    Posts: 2129 from 2003/3/1
    AFAIK you cant mount Mac volumes in MOS???
    magnetic
  • »27.12.05 - 15:27
    artickfox
    Posts: 101 from 2004/4/17
    You need to have the filesystem support to make MOS use these disk: you can simply find these on Aminet.
    For Linux, you probably need to have EXT2 or EXT3 support to use them (howerer control what kind of FS you really have on that disk...). For MacOS i don't know what kind of FS use...  :-?
    Virtual Paws:
    http://www.furryitalia.net/virtualpaws/index.htm
    Italian furry videogame site
    Furry Italia
    Italian Furry Comunity
    - Owner of a Pegasos 2/G3 -
  • »28.12.05 - 09:10
    analogkid
    Posts: 722 from 2004/11/3
    I don't know if OS X still uses HFS, but if so, it should be possible to use a HFS-capable CDROM-FS like AmiCDFS.
  • »28.12.05 - 09:55
