Amithlon TV Card - Installation help
    TrevorDick
    Posts: 130 from 2005/10/12
    My new Pegasos II came installed with a LifeView Flyvideo TV card and Amihlon 2.2 software and drivers. However when I try to configure the card I get several error messages when I try either an auto or manual install. If I select the LifeView Flyvideo card manually I can tune in a TV channel and the picture is OK but the sound is highly distorted and is drowned out by a loud hiss.
    I tried re-istalling the Amithlon software using the installer from OS3.9 as I was informed that the native MorphOS installer is buggy? However the response was exactly the same after de-installing and re-installing the Amithlon software.  :-? I apologise if this topic has been covered before.
  • »16.12.05 - 00:45
    Bladerunner
    Posts: 418 from 2004/2/19
    Unfortunately I can`t help you on the the topic, but
    There is no native Installer for MorphOS, and given the animosity some people have against installers, I doubt there ever will be one ;) Which is to bad, because *actually* I like Installer, although it need a major overhaul.
  • »16.12.05 - 05:49
    TrevorDick
    oops! Obviously misunderstood :-?
    Can anyone else help with my TV card installtion problem?
    TrevorDick
  • »16.12.05 - 09:36
    Posts: 1087 from 2003/3/24
    Why you didn't try Visionary? You can find it here: http://grex.amigaworld.de/index.php?lang=en&page=14
    You need V.15 or V0.22 and the SkinsTV package.
  • »16.12.05 - 10:03
    TrevorDick
    Thanks I'll download it and give it a try.
    TrevorDick
  • »16.12.05 - 17:08
    TrevorDick
    OK downloaded and installed Visionary. Vey clear interface but once the channels were tuned in it gave me very similar results to the Amithlon software. Reasonable picture quality with a very lound hiss and TV sound barely audible. Any ideas?
    TrevorDick  :-?
  • »16.12.05 - 18:21
    How is the Soundoutput of your TV-Card connected to the Peg? Maybe the cabel is faulty or the Card it self is it.
  • »17.12.05 - 10:42
    TrevorDick
    I connected the speakers directly to the output on the video card.
    TrevorDick
    [ Edited by TrevorDick on 2005/12/18 6:00 ]
  • »17.12.05 - 20:58
    Mi-Go
    Posts: 95 from 2003/9/18
    Since you're talking about it, I'll "abuse" this thread asking a question about visionary, hope you don't mind... ;-)
    I have a Pinnacle PCTV (which works great on linux) but can't manage to tune the channels, are there some guides around or is it so easy there is no need for a manual (i.e. my card isn't supported)?
    or, simply, how did you tune the channels?
  • »18.12.05 - 00:51
    Go to the Prefs in Visionary and autoscan the broadcast channels.
  • »18.12.05 - 13:48
    Mi-Go
    ...so it's not supported... :-(
    well, actually nothing happens, it starts scanning, the flickering lines change, but in the end no channel is found. I tried to enable the debug option (both tooltype and cli) but I got no output.
  • »18.12.05 - 14:57
    Then your card isn't supported. Or the revision of the Card is the wrong one.
    Had this problem with my WinTV.
  • »18.12.05 - 19:44
