Posts: 204 from 2003/12/29
A bit late, but I just updated MorphOS from 1.4.4 to 1.4.5, just to try the 3D support of Radeon :)
It seems the Ambient version is updated, and now comes with a "feature" that automatically resizes icons. I had a pretty icon (from Lum) which now seems small even in Huge... I want it bigger ^^;
Can't I use that icon's original size?
BTW, how do you check the MorphOS version? It still says 1.4 ... ^^;
Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
-- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
-- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
EFIKA
