pSDL and Bochs(2.2) and DosBox(latest)
    Posts: 98 from 2004/6/4
    I have a rather strange glitch in my compilation of Bochs 2.2 and the latest DosBox. None of the keys with Shift pressed work. It might be that SDL returns scancodes for example for "A" and "a" not same +SDLK_*SHIFT in case of "A" as expected by those programs, but as natural scancodes without qualifier key. Tho I have a multiple "SDL: unknown scancode NN" error in bochs log. :-?
    Does anyone else have the same problem?
    WBR, Vladimir Berezenko
  • »09.11.05 - 11:29
    Posts: 108 from 2005/4/3
    Hi all,
    WordPad from Windows98 in Bochs 2.2 accept capital charracters when
    pressing the "shift" key together with "A" gives "A". Pressing "A"
    without "shift" key pressed gives "a". I don't use the SDL library,
    seems to work OK, but not tested. Offcourse, you compiled on your own.
    However, i remember having trouble with some charracters in
    DosBox.
    grts, Amigaharry,
    Visit my homepage for classic Amiga and MorphOS proggies written in
    machinecode;
    http://www.angelfire.com/amiga/ex
  • »10.11.05 - 18:10
    DosBox.
    The problem exists only in SDL mode. I've found the problem I think, but I can't fix it now coz my Peg is at home and I am in another city. 8( The problem is in mapping function which calls MapRawKey();
  • »11.11.05 - 08:08
