In the Spring.. Grand Paihia!
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    from the site http://www.paihia.co.uk/
    " Grande Paihia is a modern, small, fast, and portable web browser. With complete support for XML, HTML 4, CSS 2.1, DOM level 3, and EcmaScript 3, Grande Paihia is more than capable of dealing with most of your internet needs. Grande Paihia is written from the ground up and is not based on any existing web software.
    Versions for all the various Amiga systems are planned. Progress is slow but steady. As of November 2005, the CSS engine is all but done and being tested using the W3C test suite - biggest issue to arise from testing is performance. The language parts of EcmaScript are done, the object library isn't. And DOM level 3 is about 20% complete. All of this and the source code for the Paihia web engine is less than 700k uncompressed. Visual Studio compiles the engine to a binary around 300k in size - a tiny fraction the size of anything else in the field! "
    Sounds great! Should this be a news item or a forum post?
  • »06.11.05 - 06:36
    pixie
    Posts: 148 from 2003/9/5
    Go Go news items post ;-)
    pixie - writing from a paradise called Portugal
  • »06.11.05 - 21:34
  • News Moderator
    News Moderator
    Darth_X
    Well I think it should be released before it becomes a news item. Just a website update isn't enough for a news item is it?
  • »06.11.05 - 22:46
    Krashan
    Posts: 1107 from 2003/6/11
    Paihia belongs to the same group as Amy'05 and MorphOS 1.5. Probability of their future existence is very low.
  • »07.11.05 - 12:16
    pixie
    As of MorphOS 1.5, I rather think it's rather a semantic thing, as for Grande Paihia, well... they showed it's progress sometime ago, not as much as the all mighty KHTML from Marcik but... ;-)
    I mean, if you only put in the news either of them (KHTML or Paihia) when they're ready it would be way too much for people to 'swallow'! We're not ready for such big news all at once! :-p
    [ Edited by pixie on 2005/11/7 20:56 ]
  • »07.11.05 - 13:55
