Radeon Screen Corruption + Pegasos II
    amigakit
    Posts: 44 from 2005/8/24
    Building a Pegasos II here with firmware v 1.2 (20050808153840)
    When a Voodoo 3000 PCI is used as the graphics card, the system boots without any screen corruption.
    However when a AGP Radeon 9200SE 128MB or Radeon 9250 256MB is used, the screen is heavily corrupted but the system is still functional
    What is the fix for this problem?
    Incidentally, the early bootup screens are all fine. Corruptions starts when the Morphos butterfly logo is display and Ambient is also corrupted.
    Thanks.
    [ Edited by amigakit on 2005/11/6 0:23 ]
    www.amigakit.com - Amiga store
  • »05.11.05 - 15:20
    Posts: 916 from 2004/1/24
    Try adding the command "wait 1" before "IPrefs" is loaded in the startup-sequence.
  • »05.11.05 - 17:03
    amigakit
    Thanks for the reply.
    Ive tried Wait 2 as I have seen this suggested before.
    Any other ideas? Is this a known issue?
    Can the Pegasos be reflashed back to a previous firmware?
  • »05.11.05 - 17:32
    dOpus
    Posts: 42 from 2005/7/30
    Hi,same problem i have too with Radeon 9200SE 128
    mail to Bplan and get a upgrade for OF, there is the problem with the new boards.
    I don't have any problem from update.
    With the new firmware when is out, this graphic problems end forever...
    Until you get a new update make this...write a Cd with boot.img on it and boot with boot cd boot.img
    It works
    G4/1GHz,1GB DDRam,Ati Radeon 9250 128Mb
    MorphOS 2.0 demo
    Molk with MacOSX 10.4.9 Tiger
    iMac 27" 2007 2,16 MHz,1,5 Gb Ram OSX 10.6.5
    AppleTv 40Gb with external 160Gb HDD
  • »05.11.05 - 21:03
    serge
    Posts: 725 from 2003/2/20
    I'm having some trouble, but not very important.
    During boot, instead of the bootpic, I have a trashed screen.
    My normal bootscreen
    http://serge.free.free.fr/Pegasos/IMG_0394.JPG
    My trashed bootscreen
    http://serge.free.free.fr/Pegasos/IMG_0396.jpg
    Is this a firmware issue?
    Ambient is good for me.
    PEG II FW 1.2
    Radeon 7000
    [ Edited by serge on 2005/11/6 17:48 ]
  • »06.11.05 - 07:46
    tokai
    Posts: 1289 from 2003/2/25
    @serge:
    no, its some bug/effect which appeared when u save new publicscreens prefs with new MUI4 beta. the weird and funky blinking stuff is normal for radeon when u boot w/o bootimg (which is the effect u encounter now). A solution is to use old env:sys/publicscreens.prefs file from some backup and don't save new one with MUI4 beta.
    regards,
    tokai
  • »06.11.05 - 08:40
    deez
    Posts: 53 from 2003/5/28
    @tokai:
    Hmm. I have the same problem on the radeon 8500LE, only colours are different, green instead red. I never used MUI4 on my MorphOS.
    [ Edited by deez on 2005/11/8 23:39 ]
  • »06.11.05 - 13:08
    serge
    @ Tokai,
    You are completly write about my problem.
    I changed the pubscreen file and it works great now.
    Thank you very much.
    @ deez,
    I used a radeon 9200 and had the same colours like you.
    The problem disappeared for the radeon 9200 after the file be changed.
  • »06.11.05 - 21:34
