VGP-2 for early XMAS !!!
    Robin
    Posts: 741 from 2003/2/24
    :-) Dont forget to donate :-D
    http://www.virtualgrandprix2.com/
  • »31.10.05 - 18:13
    Jupp3
    Posts: 1193 from 2003/2/24
    Wow, that's something I didn't expect quite yet :-)
  • »31.10.05 - 21:44
    Posts: 918 from 2004/1/24
    8-D
    Fantastic news!
    :bloons:
  • »01.11.05 - 06:08
    flip
    Posts: 38 from 2005/8/25
    Awesome Game!!! :-o :-o :-o :-o
    10X a lot Paolo "The Alien" Cattani ;-)
    :pint: :bloons: :pint: :bloons:
  • »01.11.05 - 15:32
    Angelos
    Posts: 17 from 2003/4/6
    thanks a lot.
    support for my logitech wingman would be appreciated.
    Regards,
    Angelos
  • »01.11.05 - 16:34
    Mi-Go
    Posts: 95 from 2003/9/18
    simply great! :bloons: :bloons:
    I've got a problem switching camera angle, though. Am I the only one?
  • »02.11.05 - 11:41
    hooligan
    Posts: 1948 from 2003/2/23
    @Mi-Go
    Yep. 1-2 views work, 3-4 are only flickering screen. Whats your problem? And setup?
  • »02.11.05 - 13:32
    Posts: 1087 from 2003/3/24
    For me just view 1,3 and 4 works, and i can't use my USB-Joypad with VGP2.
    It's very hard to play with mouse or Keyboard.
  • »02.11.05 - 13:40
    matt3
    Posts: 784 from 2004/2/10
    Runs fine here... G4/512mb/Voodoo3500
    All 4 screenmodes work. Indy Game Port Steering Wheel and Logitec Wingman USB are no goes for steering.
    Matt
    [ Edited by matt3 on 2005/11/2 20:45 ]
  • »02.11.05 - 14:31
    guruman
    Posts: 462 from 2003/7/21
    I guess only analog USB input devices are supported, and those need Poseidon 3 (as Chris Hodges aknowledged on amiga-news.de). A digital USB joypad would work just like the keyboard. At the moment I'd suggest to practice withthe mouse.
    Kind regards,
    Andrea
  • »02.11.05 - 15:19
    Mi-Go
    Just the same... any view but the inside one either flickers a lot on a still image or works for a few moments and then starts flickering like hell ;-)
  • »02.11.05 - 18:48
    hooligan
    FINALLY!!!
    People started to think I invented this problem inside my head ;-)
    You have the exact same symptoms I have. I use Radeon 9100, 256mb of ram, Pegasos2/G4. You?
  • »03.11.05 - 02:54
    Mi-Go
    More or less... Peg2 G4 512mb RAM and Radeon 8500LE (or something... ;-))
    Anyway, it's a shame not being able to see 2004 car models in their full beauty from outside :-(
  • »03.11.05 - 08:19
    guruman
    Ok. I have told Paolo about this problem, no guarantee it'll be solved, of course  ;-) Since the 9100 is a rebranded 8500LE (exactly same chipset and specs AFAIK), it might be there that lies the problem...
    Kind regards,
    Andrea
  • »03.11.05 - 10:58
    Mi-Go
    @guruman
    Grazie :-)
  • »03.11.05 - 13:32
    VooDoo
    Posts: 189 from 2005/8/24
    Great game..but what is minimal configuration for runing this game? its possible to run VGP2 on MOS PowerUP?
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1  :-D
    Warp croatian Amiga portal :
  • »04.11.05 - 14:00
    guruman
    Well, you need the 3D update with the newest tinygl.library, that should support only Voodoo3s on GRex right now (anyone tried?). Then you'll probably need at least 128MB of memory, I guess.
    Kind regards,
    Andrea
    EDIT:typos
    [ Edited by guruman on 2005/11/5 6:00 ]
  • »04.11.05 - 14:42
    VooDoo
    @guruman
    Thanks on info..maybe you know..any mos update soon? driver for FastATA ot 3D driver for Bvision...
    A1200 sandwich
  • »04.11.05 - 19:44
    wlamee
    Posts: 59 from 2004/2/18
    Hey all, here's my 2 cents:
    I'm running VGP2 on my Peg2 with a Radeon 7000 ATI card, and pressing keys '1' and '2' both seem to be an in-car view, pressing '3' switches between in-car / a little bit above and behind / a lot above and behind / before the car looking back. Key '4' gives the camera view.
    All views seem flicker-free and doing what they should do. I also have a 9200 card lying around, which I could test.
    But I also can not get any analog devices to work. I have a steering wheel and a stick, both of which I used on my Amiga with a home-made converter from 15 to 9 pins. In this converter, I also put some capacitors to take the resistance down to the proper levels.
    On the Peg2 I am of course plugging them into the game port, but it does not work at all. I tried VGP2 and Descent II, in VGP2 I could get some jerky left/right movement, in Descent II nothing at all (except firing).
    Is there anybody who got any analog device (analog stick, steering wheel, anything) to work on the Peg?
    Or are these capacitors (which are necessary to use the analog devices on the Amiga) also needed on the 15-pin connectors for the Peg?
    Questions, questions, I donated a few times to Paolo anyway.
    Wouter Lamee
    mailto:wouter@wouterlamee.nl
    http://www.wouterlamee.nl
  • »04.11.05 - 20:02
    Wishmaster
    Posts: 342 from 2003/6/29
    Analogue devices are not supported, yet.
    What do you think, can this be the reason that your analoue stick is not working?
    Or maybe some evil sorcerers are the reason or some telepathic waves you are emitting. In this case contact your psychologist or fortune-teller.
    Pegasos PPC
  • »05.11.05 - 07:42
    serge
    Posts: 725 from 2003/2/20
    runs like a charme at home.
    I like it !
    Fun fun fun and more fun on PEG world.
    Thanks to the author.
  • »06.11.05 - 07:52
