How do I get closer to Java?
    wlamee
    Posts: 59 from 2004/2/18
    I'm looking for ways to get things like Java and a reasonably current IE browser (yes, I know, don't get me started) going on my Peg2. I read here and there that the PC emu does work properly, but is chugging along like a 20MHz machine.
    How's the Mac emu, does that allow me to do Java and IE stuff if I get the right bits installed?
    And if so, which versions of what programs should I use?
    Wouter Lamee
    mailto:wouter@wouterlamee.nl
    http://www.wouterlamee.nl
  • »27.10.05 - 14:59
    Posts: 1082 from 2003/3/24
    If you have Linux installed you could try MacOnLinux or PegXMac.
    With MOL you can use MacOS9 to MacOS X Tiger.
    It only lacks 3D Hardware Support.
    [ Edited by ThePlayer on 2005/10/28 2:34 ]
  • »27.10.05 - 16:32
    wlamee
    So that's starting from Linux. Any particular version or is there a recommended version?
    And this means no emu is possible starting from MorphOS?
    Wouter Lamee
  • »27.10.05 - 19:31
    amiades
    Posts: 231 from 2005/6/2
    You can always use RDesktop to connect to a windows workstation, and using the remote desktop, run the programs you want... It's an awfull solution, but perhaps it can help ;).
  • »27.10.05 - 20:46
    If you don't want to use Linux, try Pegxmac. It's Linux based but it is very easy to use for a Linux newbie.
    With Pegxmac you can boot right into MOL with MacOS X installed. I use it like that with OS X 10.3.9
  • »28.10.05 - 02:34
    Wishmaster
    Posts: 342 from 2003/6/29
    Basilisk should run MacOS8, don't know what the browsers are like.
    Pegasos PPC
  • »28.10.05 - 03:08
    wlamee
    I guess this means I have to get a Linux partition to boot from. Where can I best get that from then, some CD image for my Peg2 I can d/l from some place?
    Wouter Lamee
  • »31.10.05 - 19:54
