What's with my WBStartup?
    wlamee
    Posts: 59 from 2004/2/18
    Hey all,
    I don't remember exactly since when, but I think since the MOS upgrade to 1.4.? I can not get my WBStartup drawer to work as it should: One or more of the programs in there (that always worked on the Amiga and in previous MOS versions) just hangs (=never returns) and prevents the startup-procedure from ever finishing.
    For over a year now, every time I start my MOS 1.4.latest machine, I have to start all my WBStartup apps by hand (from another dir, so the machine actually finishes booting).
    I have the following apps in my startup: Miami 3.2b (regged), SGrab, SnoopDos, dnetc, DPMS and JabberWocky 1.6p1.
    I have tried to add DONOTWAIT to each of them, but no luck. What has changed in this MOS realease regarding WBStartup and what do I need to do to make it work again?
    Wouter Lamee
    mailto:wouter@wouterlamee.nl
    http://www.wouterlamee.nl
  • »27.10.05 - 14:50
    Chain-Q
    Posts: 350 from 2003/10/12
    Early 1.41 Ambient builds used to cause this. Maybe you're using one of them? It's MOS 1.4.x specific, and it was fixed quite a while ago. Also 1.41SE in MOS 1.4.5 shouldn't be affected, IIRC.
    [.Hosting AmigaSpirit.hu.]
  • »27.10.05 - 15:07
    wlamee
    Just picked the latest version off Sourceforge. It is fixed indeed, that's a lot better. And that was me waiting for something called 'a stable release' before upgrading. :-P
    Wouter Lamee
  • »27.10.05 - 19:53
    Posts: 1074 from 2003/3/24
    LOL
  • »28.10.05 - 02:37
