FPSE-HOWTO
    diezi7
    Posts: 167 from 2005/7/25
    Has anyone succesfully used FPSE in MorphOS?
    I´ve tried many times but I can find the problem.
    Do I need OS4Emu I suppose, any other library or tool?
    Snoopium does not tell me nothing interesting.
    Are games at least playable?
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »18.10.05 - 12:30
    Posts: 1520 from 2003/2/24
    You need OS4Emu and you must install LoadSeg() patch so MorphOS can load OS4 binaries directly. Patch is included in the emulation package, it is C/PatchLoadSegOS4.
    Most programs run without patching but FPSE is not one of them.
    I never tried any game on i but one demo I tried worked just fine.
  • »18.10.05 - 12:54
    diezi7
    Hi ;-D
    OS4 Emu and LoadSeg are both installed.
    I use the GUI, save the prefs, launch the
    program, select screenmode. And the window
    opens and closes inmediately.
    And how about that demo you tested?
    Thx
  • »18.10.05 - 13:29
    serge
    Posts: 725 from 2003/2/20
    are you using a good PSX BIOS file ?
    It works very well at home.
    my parameters
    http://serge.free.free.fr/Pegasos/1.png
    http://serge.free.free.fr/Pegasos/2.png
    http://serge.free.free.fr/Pegasos/3.png
    http://serge.free.free.fr/Pegasos/fpse.ini
    [ Edited by serge on 2005/10/19 4:16 ]
  • »18.10.05 - 18:08
    ChaoZer
    Posts: 13 from 2004/2/4
    Most games run (pretty much) full speed.
  • »20.10.05 - 01:08
    thefab
    Posts: 92 from 2003/8/19
    did you test with iso image or real cd?
    have you change the cdimage/cdrom module in the config file to suit the right support?
    btw, the gui included with fpse doesn't work very well, works better from a shell here.
  • »21.10.05 - 07:59
    diezi7
    Finally it worked, thanks for your kind help.
    Serge, I think it was a bad bios file
    as you pointed out.
    Now it runs and it´s playable enough
    I´m thinking bout using an usb PC Joypad
    I have, maybe Poseidon recognizes it and
    it could be easier to play games.
    XDD
  • »25.10.05 - 17:34
    Posts: 1082 from 2003/3/24
    FPSE lacks Joypad support.
    But you can bind the Keys to the USB-Pad with Poseidon.
  • »25.10.05 - 18:14
