Problems with Radeon and 3D on Peg1
    analogkid
    Posts: 722 from 2004/11/3
    hi,
    i've got a problem with my Peg1, an ATI Radeon 7000 64 MByte, and the new 3D driver set. Some(Most)times when a 3D app is started, a grey window opens and MorphOS hangs. sometimes it works. What could be the problem?
    Config: Peg1, 1 Gbyte RAM (single RAM module), ATI Radeon 7000 64 Mbyte)
  • »31.08.05 - 10:46
    bigfoot
    Posts: 510 from 2003/4/11
    Can you send me the output of pciscan by email to bigfoot@private.dk?
    Also the MorphOS debug log would needed, so if you can catch it by serial or ramdebug, it would be of great help. If ramdebug doesn't survive a reset, try to get it one of those times when running a 3D app does work.
  • »31.08.05 - 11:02
    jcmarcos
    Posts: 1178 from 2003/3/13
    Wow! Is this SUPPORT or what! :-D
    (sorry for the otherwise useless post, couldn't resist my own enthusiasm!)
  • »31.08.05 - 13:26
  • Leo
    Leo
    Posts: 427 from 2003/8/18
    I am having same kind of problems...
    Peg1-Radeon 7500
    Leo.
  • »31.08.05 - 14:21
    Bifford
    Posts: 283 from 2003/2/24
    Hiya.
    I also get the grey screen, but this is on a peg II/G4.
    Also, one program (Payback ppc version) opens but has the top and bottom inch of the screen flickering like mad! kills my eyes.
    Havn't tested more than a few things yet though.
    Sam
    Bifford the Youngest
  • »31.08.05 - 14:57
    Posts: 1087 from 2003/3/24
    I have the same "top and bottom inch of the screen flickering" with Heretic2
  • »31.08.05 - 18:52
    analogkid
    @bigfoot: i've sent you both the pci list and debug output.
  • »02.09.05 - 14:14
    Schlonz
    Posts: 131 from 2004/4/16
    @ThePlayer:
    This flickering thingy usually happens when you choose a screen mode which does not exists which will be mapped to the next, bigger one. Example: you choose 1280x960, but this screenmode is not available, so the program will run on 1280x1024 (if that one is available), so 64 pixels on the top of the screen will flicker like hell.
    Solution: go to the System prefs, choose Mode Edit, create a suitable screen.
    @Bifford:
    Did you run Payback setup and choosed a screen which does really exist? (Maybe you changed your graphics card since you last tried Payback)
    Does this flickering only happen with the WOS version or does it happen with the 68k version as well?
  • »03.09.05 - 19:05
    igracki
    Posts: 471 from 2003/2/24
    are there some news concerning this problem?
    I have it here too on my Peg1;-(
  • »15.09.05 - 17:16
    analogkid
    i've mailed bigfoot both pcicard list and debug output, but he didn't answered yet.
    [ Edited by analogkid on 2005/9/15 22:04 ]
  • »15.09.05 - 19:02
    craf
    Posts: 1 from 2005/9/5
    I have also the same problem some games started ... and after the
    monitor screen is black... i must reset my computer...
    is it a driver problem ?
    My peg 1 256 mo ram and a radeon 7200 32 megs sdram.
  • »15.09.05 - 19:47
    analogkid
    Today I tried a Radeon 7500, and the same error occurs.
    @bigfoot: are there any news concerning this ?
  • »20.10.05 - 10:16
    Crumb
    Posts: 738 from 2003/2/24
    are you using MOS 1.4.5?
    MOS1.4.2 Radeon driver won't work
  • »20.10.05 - 19:17
    analogkid
    yes, I'm using MOS 1.4.5
  • »21.10.05 - 07:07
