Posts: 426 from 2003/8/18
I just tried the new Linux live CD called "Niktarix" available from here: http://www.ppczone.org/forums/viewtopic.php?t=220
It seemed to work perfectly but after a while network just stopped working. Setting eth0 to down then up did not do it. Neither did a reset and a shutdown. Worst: after powering on the computer again, the network didn't work anymore (under both MorphOS and Linux itself).
The only thing that could make it work was to shutdown the computer, unplug network cables for 10-15 minutes.
=> I'm not the only one who had problems with the very same distribution: you've been warned !! :)
Config: Peg2-G3, Net: Internal VIA
Regards,
Leo.
Before you ask: I tried to submit a reply on the thread at ppczone but because of an error in some script, I couldn't register on the site for an account... so if you have an account there, tell the author about the problem when registering and reply to the thread with this message: thanks !
[ Edited by Leo on 2005/10/18 19:56 ]
