I put on dvd all the *really* important stuff, deleted dh2: and made it again with scsiconfig. nothing changed (error still on 5155) but now linux goes in kernel panic while booting... guess that backup was the right thing
Sounds like your HD might have some bad sectors
Is it possible to overcome this problem somehow? AFAIK there is no SFSSalv (yet?)...
###SFSCheck Output (since I can't see the attached file in the first post###
Partition start offset : 0x00000000:2316E600 End offset : 0x00000002:944B0A00
Surfaces : 1 Blocks/Track : 4771
Bytes/Block : 512 Sectors/Block : 1
Total blocks : 20486674 Size : 10003,2MB/9973,4MB (1%)
Device interface : TD64 Version : 1.210
Device buffers : 600 Device caches : 32x16384 (524288 bytes) [CPB]
Checking RootBlocks
...okay
Checking Config Block at block 20486672
Reserved areas in config block weren't all set to zero.
...damaged
Checking AdminSpaceContainers at block 2
...okay
Checking NodeContainers at block 7
...okay
Checking ObjectContainers at block 3
...okay
Checking Bitmap at block 34 (5122 blocks, 4000 bits/bitmap)
0 FFFF8000 == FFFF0000
Bitmap block 5155 contents is incorrect!
...error in bitmap block at block 5155.
...damaged
