USB keyboard question
    x56h34
    Posts: 29 from 2004/11/1
    Is it possible to use a USB keyboard as your default choice within SmartFirmware console?
    Thanks. :-)
  • »07.10.05 - 22:45
    Bladerunner
    Posts: 418 from 2004/2/19
    If you have a Peg II, yes, but (at least in my case with a Cherry Keyboard) with some limitations (iirc F Keys, Console History and pressed key (meaning you have to press backspace for every character you want to delete) are not working yet).
    Otoh it is enough if you have installed a boot menu, or if you just want to type in some boot parameter from time to time.
  • »07.10.05 - 23:09
