Radeon 9200Pro screenmode problems
  • rms
    rms
    Posts: 606 from 2004/11/27
    Hi all,
    I use a Radeon 9250 with 128 MB and have screenmode problems with it. 1st I thought that the gfx card is faulty but after having replaced it the problem is still here!!!!
    You can have a look at:
    http://www.rmsvideo.ch/public_rms/radeon9200pro.jpg
    In fact several tests have been made and it seems that when MUI 4 alpha is installed over MorphOS 1.4.5 the problems are gone, those strange signs arn't there anymore.
    Well is the Radeon 9250 not supported anymore? In fact on the gfx card itself it's stated Radeon9250 128 MB. So it is strange that MorphOS stats Radeon9200Pro.
    Does anybody know what could be the problems when using the gfx card with those strange signs?
    Or what are the problems with MUI 4?
    I use the Pegasos and MorphOS professionnally, at least 8 hours per day, so I cant realy afford problems.
    Thanks in advance for your help in this matter.
    Regards
    Christoph
  • »06.10.05 - 07:33
    DJBase
    Posts: 745 from 2003/4/6
    Just ignore these signs. The Radeon 9250 is full working. The card was ever detected as 9200PRO so noting to be afraid about.
    [ Edited by DJBase on 2005/10/6 15:31 ]
  • »06.10.05 - 08:31
