MorphOS Developer
Posts: 619 from 2005/8/27
PS: a note on gcc. What about gcc3? That guy nominated in this post has tried a compilation of Amanith, obtaining tons of such errors "sorry, not implemented: 'tree_list' not supported by dump_expr". STL seem also not supported. Is c++ not needed by Amiga community?
STL is supported, but you need to get a fully working cc1plus from
this archive (I hope it's still there), also you should copy g++ and libstdc++.a from there (remember to disable/remove GCCRESIDENT envvar!) .. the tree_list/dump_expr problem could be related to that, but if it doesn't go away, try increasing stack (with ixstack tool) on cc1 and/or cc1plus...
Are there some experimental new versions not yet officially released but available?
Yes, because we firmly believe the newer version are not yet mature (they still produce wrong code quite alot) enough for general use (yes, I know there are some ppl who disagree with this, but instead of arguing about it, compile GCC3/4 yourself if you feel you *must* have it) .. we still build and check out every new release for improvements, so when we think the time is right, there will be an updated GCC...
- CISC
