CD32-live MIGHTY RELAUNCH :)
    serge
    Posts: 725 from 2003/2/20
    # XF86Config-4 (XFree86 X Window System server configuration file)
    # This file was generated by dexconf, the Debian X Configuration tool, using
    # values from the debconf database.
    # Edit this file with caution, and see the XF86Config-4 manual page.
    # (Type "man XF86Config-4" at the shell prompt.)
    # This file is automatically updated on xserver-xfree86 package upgrades *only*
    # if it has not been modified since the last upgrade of the xserver-xfree86
    # package.
    # If you have edited this file but would like it to be automatically updated
    # again, run the following commands as root:
    # cp /etc/X11/XF86Config-4 /etc/X11/XF86Config-4.custom
    # md5sum /etc/X11/XF86Config-4 >/var/lib/xfree86/XF86Config-4.md5sum
    # dpkg-reconfigure xserver-xfree86
    Section "Files"
    FontPath "unix/:7100" # local font server
    # if the local font server has problems, we can fall back on these
    FontPath "/usr/lib/X11/fonts/misc"
    FontPath "/usr/lib/X11/fonts/cyrillic"
    FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
    FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
    FontPath "/usr/lib/X11/fonts/Type1"
    FontPath "/usr/lib/X11/fonts/CID"
    FontPath "/usr/lib/X11/fonts/Speedo"
    FontPath "/usr/lib/X11/fonts/100dpi"
    FontPath "/usr/lib/X11/fonts/75dpi"
    EndSection
    Section "Module"
    Load "bitmap"
    Load "dbe"
    Load "ddc"
    Load "dri"
    Load "extmod"
    Load "freetype"
    Load "glx"
    Load "int10"
    Load "record"
    Load "speedo"
    Load "type1"
    Load "vbe"
    EndSection
    Section "InputDevice"
    Identifier "Generic Keyboard"
    Driver "keyboard"
    Option "CoreKeyboard"
    Option "XkbRules" "xfree86"
    Option "XkbModel" "pc105"
    Option "XkbLayout" "fr"
    EndSection
    Identifier "Configured Mouse"
    Driver "mouse"
    Option "CorePointer"
    Option "Device" "/dev/psaux"
    Option "Protocol" "PS/2"
    Option "Emulate3Buttons" "true"
    Option "ZAxisMapping" "4 5"
    EndSection
    Identifier "Generic Mouse"
    Driver "mouse"
    Option "SendCoreEvents" "true"
    Option "Device" "/dev/input/mice"
    Option "Protocol" "ImPS/2"
    EndSection
    Section "Device"
    Identifier "Carte vidéo générique"
    Driver "ati"
    EndSection
    Section "Monitor"
    Identifier "Écran générique"
    HorizSync 30-50
    VertRefresh 50-80
    Option "DPMS"
    EndSection
    Section "Screen"
    Identifier "Default Screen"
    Device "Carte vidéo générique"
    Monitor "Écran générique"
    DefaultDepth 24
    SubSection "Display"
    Depth 1
    Modes "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480"
    EndSubSection
    Depth 4
    EndSubSection
    Depth 8
    EndSubSection
    Depth 15
    EndSubSection
    Depth 16
    EndSubSection
    Depth 24
    EndSubSection
    EndSection
    Section "ServerLayout"
    Identifier "Default Layout"
    Screen "Default Screen"
    InputDevice "Generic Keyboard"
    InputDevice "Configured Mouse"
    InputDevice "Generic Mouse"
    EndSection
    Section "DRI"
    Mode 0666
    EndSection
  • »16.08.05 - 19:19
    Frostwork
    Posts: 302 from 2003/4/18
    Hi!
    HD-install script is almost complete :)
    Upgraded doomsday to 1.9.0beta2
    (& added midi-support...)
    several minor things...
    THX, serge, I'll check it out...
    cheers
    frostwork
    edit: xmame 0.99 is out, so I'll speed up finishing... ;)
    [ Edited by Frostwork on 2005/8/17 19:25 ]
  • »17.08.05 - 15:22
    Frostwork
    yep.
    serge's (slighty modified) xorg.cfg works.
    Default is still mine, but you'll only have to replace
    mine (/cfgs/xorg.conf or /cfgs/xorg.conf-NTSC) with serge's
    (/cfgs/xorg.conf-serge)
    xmame is now on 0.99, xmess will stay on 0.97 as gameboy-emulator
    seems to want a bios in the new version...
    Still some things to do, but I think it'll be finished in (max) 1 week...
    frostwork
    ps: @klapdeur:
    already tried s.th with peg1-kernel?
  • »19.08.05 - 12:55
    Frostwork
    Finished....
    Will go out tomorrow to gunne via snailmail
    Features:
    - live boot into cd32-cd in 2nd drive
    (or 1st when cd32live is hd-installed..)
    - starts cd32-isos
    - launches menu with following emulators
    - euae 0.8.28RC2
    - xmame 0.99
    - xmess 0.97
    - generator 0.35-cbiere
    - snes9x 1.43
    - VisualBoyAdvance
    - AlephOne 1-3
    - Doomsday 1.9.0-beta2
    - direct support for AmigaClassiX4
    - (usb-) hds can be used to read/write games/cfgs etc...
    - completely installable to hd
    - tv-out support (Radeon only)
    frostwork
  • »24.08.05 - 09:46
    serge
    is this live cd downloadable
    atm?
  • »29.08.05 - 18:58
    gunne
    Posts: 441 from 2003/2/25
    Not yet, it will soon be.
    Gunne
    Best wishes, Gunne
  • »29.08.05 - 19:37
    Posts: 918 from 2004/1/24
    And here it is :-)
    https://morph.zone/modules/mydownloads/singlefile.php?lid=326
  • »31.08.05 - 05:35
