a list of compatibility
    Posts: 2 from 2005/7/28
    Hi
    I want to know where i can find a complet list of compatibility with digital cameras, soundcards, webcam etc. which works with pegasos II ?
    Pegasos II G4 1MHz
  • »21.08.05 - 19:17
    Velcro_SP
    Posts: 929 from 2003/7/13
    Make life easy on yourself and get a camera that works with PTPDigCam software by Christophe Genre.
    The Kodak C300 is one such model, goes for about $100. That's what I have.
    According to the readme PTPDigCam has been tested with:
    Kodak CX6200
    Kodak CX6230
    Kodak DX3500
    Kodak DX4530
    Kodak LS443
    Canon EOS 300D
    Canon IXUS 500
    Canon A70
    Canon S1 IS
    Sony DSC-P52
    Sony DSC-V1
    Sony MVC-CD300
    Yeah, I know the C300 is not listed there, but I tried it and it works great. I think it's a question of the camera supporting a PTP standard, if it does than it works.
    Pegasos2 G3, 512 megs RAM
  • »21.08.05 - 22:35
    analogkid
    Posts: 722 from 2004/11/3
    no compatiblity list is complete, but here is a rough list for Poseidon, the USB stack used in MorphOS
    http://www.e3b.de/usb/
    Instead of using the onboard-sound chip, you can only use a SB Live under MorphOS
    graphics card compatiblity is shown under the following link:
    http://www.morphos.org/support.php3
  • »22.08.05 - 05:35
    Posts: 2095 from 2003/6/4
    Use a card reader to transfer pics from camera to pegasos if your camera does not work instantly. It's no big hassle.
    I use a Nikon Coolpix which mounts unreliably if connected directly, switched to a Vivanco card reader which works flawlessly.
  • »22.08.05 - 08:20
    analogkid
    you're right, i've forgotten this one ;-)
    FM801 cards theoretically works with OpenPCI and GRex driver, am I right ?
  • »22.08.05 - 10:55
