PowerSDL library
    serge
    Posts: 725 from 2003/2/20
    I installed the last E-UAE 0.8.28 RC2 and unfortunatly it doesnt wors
    like the older. I have trouble with keyboard. Cant insert floppies,
    reset quit etc.
    Searching the last powersdl library, I founded the V 11.2 on
    morphos-news site.
    Unfortunatly, after downloading it I checked the version and find it's
    11.1 like my old.
    Which is the last powersdl.library please?
  • »14.08.05 - 18:06
    Posts: 1520 from 2003/2/24
    It seems I made a mistake when creating 11.2 archive since library indeed is 11.1. But there indeed is a bug in keyboard handling in current powersdl release and it is fixed in forthcoming 11.3 bugfix release.
  • »14.08.05 - 18:23
    Norbi
    Posts: 99 from 2004/6/19
    sdl.map_raw_keys=true
    or
    LCTRL+LALT = F12
  • »14.08.05 - 18:44
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Serge,
    i let the amiga hotkey modifiers in this version (both amigaos and sdl versions), so it's not F12 but ctrl+lalt (it seems it can be overridden though in the sdl backend, according to the previous post).
    [ Edited by Fab on 2005/8/14 18:14 ]
  • »14.08.05 - 22:12
    serge
    @ Fab :
    Thank you very much Fab,
    It works great now.
  • »15.08.05 - 08:05
