Low profile TV Tuner card !
    r-tea
    Posts: 317 from 2005/3/27
    Does anyone know a low profile tv/fm tuner card which work with Visionary or AmithlonTV ?. I want to buy a slim (97mm) desktop case for Pegasos2. Ther is no problem with low profile Radeon cards but i can't find supported low profile tv tuner card.
    An additional question:
    If there is no chance to find low profile tv tuner card supported by MOrphOS software, there is a riser card solution still available, I guess, but does MorphOS support riser cards ?
    [ Edited by r-tea on 2005/8/4 10:41 ]
  • »04.08.05 - 07:12
    Posts: 3297 from 2003/3/5
    Afaik riser cards are transparent to the OS - it doesn't even know they are used.
  • »04.08.05 - 08:52
    r-tea
    Is it mechanicaly possible to use both solutions? A tv tuner card on riser card and other cards (agp and pci) directly on Pegasos board.
  • »08.08.05 - 07:45
