Bittorrent
    pegasosuser
    Posts: 138 from 2004/4/9
    I have files to download with bittorrent,
    how working that with mldonkey?
    greetings Cor van Londen. :-?
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »07.08.05 - 13:26
    analogkid
    Posts: 720 from 2004/11/3
    make sure you've opened the necessary port (usually 6881), then you
    have to get the torrent file of your downloadable files, and then you
    must add them to mld via "dllink <torrentfile>", which you have to
    type in Webinterface or in telnet interface.
  • »07.08.05 - 15:21
    pegasosuser
    how and where can I open the port 6881?
    greetings Cor van Londen.:-o
  • »07.08.05 - 15:53
    analogkid
    in which way is you Peg connected to the Internet ? If it's connected over a router, then you have to go into the interface of your router, where you've configured your account data. If it's connected directly to the DSL modem, or you've got a ISDN oder analog modem, and you've no firewall installed on MOS, there's nothing to do.
  • »07.08.05 - 16:36
    pegasosuser
    I have a A(DSL) modem.
    I canot download torrent files, I have all programs installed and configed eg: enqueuetorrent via IBrowse.
    greetings Cor van Londen. :roll:
  • »07.08.05 - 17:13
