Moderator
Posts: 2581 from 2003/2/24
@serge
My setup is rather simple so I would expect something odd on your side.
The only 3rd party SW needed are SpeedBar/SpeedButton since these aren't on newer MOS-CDs.
@Mario
SD uses RGBA (32Bit) for it's internal buffer, but all onscreen-action is done with OS-function, so you might get some slowdowns out of useing "wrong" screenmodes, but I see no reason for crashes.
@Krashan
You know blaming Stefan is allways right
I'll add those frames afap.
