AWEB release candidate
    BigGun
    Posts: 150 from 2004/6/18
    I noticed some confusion regarding the newest AWEB version.
    Please note: AWEB 3.5.06 is NOT offically released yet!
    When the relase is ready it will be available for download
    at the usual place: http://aweb.sunsite.dk/download.php
    For the brave :) that want to test it now
    and help by reporting any MOS specifyc issues.
    You can find the current release candidate here:
    http://www.greyhound-data.com/gunnar/AWEB3506rc-MOS.tgz
    (compiled 2005-07-20)
    I tried to create an archive which works out of the box.
    After decompression the archive you only need to start the install to setup a MOS specifyc config.
    Then you can run Aweb out of the decompressed folder.
    Me and the Aweb team appreciate your feedback.
    You can get back to me at Gunnar@greyhound-data.com
    Cheers
    Gunnar
  • »22.07.05 - 11:18
    poundsmack
    Posts: 1346 from 2003/6/8
    AWeb is gona rock. i cant wait till i final stable releases
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »22.07.05 - 18:11
    Posts: 1923 from 2003/10/19
    He posts!!!
    Well Aweb isnt to bad now. The one thing I find that keeps me from using it is it seems to stop receiving pages. Ut just sits there and loads nothing. If I close it and open it again it will work sometimes.
  • »23.07.05 - 12:20
    BigGun
    Hi Paul,
    Sorry Paul but your description is a bit vage.
    You are testing the new Aweb version for some month now.
    If you think that you have found any issue,
    how about helping us by filing a proper bug report?
    Gunnar
    [ Edited by BigGun on 2005/7/23 14:42 ]
  • »23.07.05 - 14:41
