USB Serial - which device?
    GK_LKA
    Posts: 481 from 2004/3/28
    Is there any device like "serial.device" for USB Serial through Poseidon?
    [ GK / LKA Team ]
  • »13.07.05 - 20:52
    Ingo
    Posts: 103 from 2004/3/19
    yes. serialpl2303.device if you are using a converter.
    I tested a converter but unfortunately poseidon drops some bytes now
    and then (to many to use the thing in RL). Back then i was mailing
    with chris but he couldn't fix it.
    So called USB-Modems/Winmodems don't work either due to lack of
    drivers.
  • »14.07.05 - 13:01
