Bochs hardfile
    td741
    Posts: 224 from 2003/4/2
    Spidey wrote about creating images...
    Well yes, it's a freeware prog called DiskImage or so?! (I forgot the name, I'll check it tomorrow at work)
    Awesome. That would be great if I can get my hands on it.
    So you're able to do more with FreeDos than I :-D
    I know I was stuck with formatting the harddrive, but the installation of Win95 was corrupt at the end. That's why I made images of the Win95 recovery floppy at my work and used that instead.
    I wouldn't mind getting a copy of your recovery floppy just to even test out that I can boot off of them.
    I tried that too (without Catweasel), but PCTask needs the original chipset or so.
    Well, it seems to work okay. Just no sound. :P Did anyone try PCx?
    Steph
  • »10.06.03 - 15:38
    Spidey
    Posts: 568 from 2003/2/24
    Hi td741,
    Just mailed it to you :-D
    Nice that PCTask works! I guess I have to try it again to see what the errormessage was exactly. :-)
    Spidey
  • »10.06.03 - 17:30
    td741
    Just saw it! Thanks for sending it! :) Worse case scenario, I can try and make the OS/2 boot disks from that. :)
    About PCTask. I'm trying to remember what I did exactly. Umm...
    It's PCTask3, not sure about 4.x. I had a coverdisk from an old CU Amiga or was it Amiga format?
    Anyway, I turned off sound, serial, parrallel. I went into advanced video settings and turned all of the video modes to "windows" although you can select a Cybergraphx screenmode too. :P
    I pointed the first floppy to "PH0:" which is the catweasel high dense floppy and created a hardfile.
    Now I'm trying to get it to boot. :) Can't seem to get it to boot off of a floppy. I get messages saying: "Non bootable or system disk" when I try my dos boot disks and such. AROS boot disk gives me a "GRUB" error. The OS/2 boot disk gives me an OS/2 error.
    However, I'm half guessing that some of the problems are due to the fact that PCTask3 only emulates a 286.
    Steph
  • »10.06.03 - 17:40
    td741
    Aha! I think I can get farther now. :P Seems like certain errors caused bochs to quit, but if I put in "ignore" it contintued on. :)
    I'm working on installing OS/2. ;)
    Hmm... Seems like getting OS/2 to work is a fruitless endeavour.
    a) If I aim for a CD install, I can build (through bochs) the two floppy disks necessary for the installation. I can boot up just fine, and get the OS/2 graphic (although the text is mangled on the OS/2 splash screen.) After a while it just crashes before getting to the actual installation.
    b) If I aim for a Disk based install, it can build the two first disks but cannot build the next disks. :(
    Oh well.
    Steph
  • »10.06.03 - 23:02
    Estrayk
    Posts: 142 from 2003/12/30
    Config: PegasosII G4/1000, 256MB DDR400, VooDoo 3000 AGP
  • »26.02.04 - 12:56
    Spidey
    Hello Estrayk,
    On the Beta2 FTP site you can find this version :-)
    Bye,
    Spidey
  • »26.02.04 - 17:08
    Estrayk
    Thanks. I get it now!  :-P
  • »26.02.04 - 20:57
    Posts: 261 from 2003/3/13
    Hello all again,
    Did you all notice a new version of Bochs is
    released (2.2) ?
    So it almost inspired me to expand the BochsGUI
    i once had made. But then i wanted to know what
    was new in this version, and i couldn't find
    what's newly supported on MorphOS, thats where
    my interest once again left me ..
    But i did manage to port/recompile/adjust a
    Linux tool named 'lomount' to MorphOS.
    lomount is used on linux to mount a diskimage
    file as harddisk, i already made this feature
    on MorphOS with BochsGUI and fat95/diskimage.
    But i changed the lomount to a usefull tool
    for MorphOS and Bochs namely: hdfileinfo.
    With hdfileinfo you can easily discover all
    info about: Cylinders, Heads and SPT.
    hdfileinfo <Path to HDFILE>
    See my plain Bochs page:
    Felix Bochs Page
    Gr,
    Felix.
  • »04.07.05 - 16:58
    Posts: 916 from 2004/1/24
    It's Felix! He's alive, HE'S ALIVE I tell you!
    Nice tool btw :-D
  • »04.07.05 - 18:04
    Hi Stevo!
    At least i think i'm alive :P
    BTW: MUI-Paint is comming to a MOS Desktop near you soon (R)
  • »04.07.05 - 19:26
    Spidey
    Hi Felix,
    Do you now know a bit more about this new Bochs? :-)
    I'll check this new version as soon as I make time to play with my Peg2 :-)
    Bye,
    Spidey
  • »12.07.05 - 08:55
