Wanted: 1.2%
    Robin
    Posts: 741 from 2003/2/24
    Sometimes I wonder where all those ppl with broadband are ;-)
    Since three days I try to load the Trigger.iso ...
    atm I've 98,8 % ...
    http://my.morphosi.net/?modul=btinfo&mode=index
    (This is an overview of my current bt-activities ...)
    I think it's time to build a network for such files.
    So when you have a flatrate and you're online 24/7
    why not put the few MorphOS-related Torrents in your
    upload queue ?
    Perhaps one day we can share a new MOS Update through
    such a channel more quickly :-)
  • »26.06.05 - 11:42
    roschmyr
    Posts: 211 from 2003/2/20
    @Robin
    i've seeded Trigger for you again :)
  • »26.06.05 - 13:36
    Robin
    @roschmyr
    Thank you :-) It's not only for me ;-) In the
    last two days I've seen a hand full of ppl with
    50 - 98,8 percent but only once for a short time
    someone with the full iso ...
    Guess I should have asked earlier :-)
  • »26.06.05 - 13:46
    Posts: 1087 from 2003/3/24
    What is that trigger thingy?
  • »26.06.05 - 19:33
    Robin
    It's a linux live-cd to run a single game (Trigger)
    http://www.positro.net/trigger/
    There is a second one (Torcs)
    http://torcs.sf.net/
  • »27.06.05 - 07:21
    DoctorMorbius_FP
    Posts: 315 from 2004/2/13
    Argh!
    The correct name for this thread now should be: Wanted 200%.
    May someone out there be so kind to re-seed both the torrents (Torcs and Trigger) again for a poor doctor who wants to play? :-D
    Thank you in advance.
    [ Edited by DoctorMorbius_FP on 2005/7/3 22:59 ]
  • »03.07.05 - 18:44
    Neko
    Posts: 301 from 2003/2/24
    Fixed :)
    trigger.iso DL 05-12 10:56 250.13 MB 1 4 1
    torcs.iso DL 05-11 16:18 246.88 MB 1 4 1
    Neko
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »03.07.05 - 20:08
    DoctorMorbius_FP
    Wow! Many thanks Neko. Just now I got the full ISO of Torcs by means of MLDonkey. I will leave the torrent available online in the next weeks.
    Instead, Triggers' download is not yet started... Moreover MLDonkey signals 0 size for the file, while Torcs had the correct size even before its dowload started. Is this meaningful or irrelevant?
    Cheers,
    DoctorMorbius_FP
  • »04.07.05 - 17:52
    Robin
    Strange thing ... I've both torrents seeding
    since I've completed them ... but sometimes
    I see ppl with a few percent but there is no
    upload-ratio here ...
  • »04.07.05 - 18:36
    DoctorMorbius_FP
    Well, I'm not used enough to BitTorrent files behaviour. It seems that people should be very trustful (usually I'm not...). After a few hours Trigger came alive abruptly and download started. Even this ISO is here now, and I'm happy: it's time to play! :-)
    DoctorMorbius_FP
    P.S.
    Thanks to all the people involved. I like to mention explicitly CISC and Tokai who gave us MLDonkey.
    [ Edited by DoctorMorbius_FP on 2005/7/5 11:05 ]
  • »05.07.05 - 06:11
    Neko
    There is ONE permanent seed for both ISOs. It is running on the same server that handles the tracker. It's upload rate is strange; but this is BitTorrent all over.
    Basically you will sit there for hours waiitng for it to send you a part, but it won't. Then when you least expect it, it will give you a part! Then it sits idle for a few hours.
    The basic premise is that there should be more seeders than downloaders, and the tracker and primary seed spread the load accordingly.
    The reason it keeled over was because the seed task quit after n hours like I told it. I since updated it again and it should be running until July 4th 2006 at best case :)
    Developer Relations
  • »05.07.05 - 12:44
